So I just got a TL and need advice
wat
04 nbp yeaaaaaaa haha.
Anyways, I was wonderin what i should get for each part.
Suspension: I really wanted to lower my car first. I was thinkin Tein basic coilovers, but I'm not into performance so would it be ok to just buy springs and put them on stock shocks? I'm scared of just buying the springs because i dont wanna screw up my tires, and shocks. I've searched and read that you dont need to buy a camber kit, and you only need an alignment. Hopefully this is true. And also, would i need struts or stuff like that?
Wheels: I dont even know where to start. I was thinking of getting 19s, but I know nothing about tire/rim size, or how compatible a certain wheel size is with the suspension that I have.
Lips: I was probably gonna get an a-spec front lip, but think ill hold off on the sideskirts/rear for now. Would that look weird?
Blackout headlight: I wanted to blackout my headlights. Like where it's cleared then painted black so the yellow markers are black.
Would this setup be decent? Sorry if I'm asking too many questions. I just dont wanna screw anything up.
welcome to the forum
If you look at the main list of threads for 3rd generation you will find most of your answers there. Just read the titles- same things you asked are all there
Also learn the search feature.
Look in the Picture area- for every combo of springs and shocks and tires, and how they look on the car
Camber kit is if you go really low- otherwise an alignment will get it close enough, toe being the important thing to adjust for now.
Make sure you know the radio and nav unit security codes thats a 4 and 5 digit number.
Register with acura as a new owner- 1-800-382-2238 x5
and here https://www.ahm-ownerlink.com/login.asp?brand=acura
You will need the cars VIN number for both of those
and here is the owner manual in case it didnt come with one
https://techinfo.honda.com/rjanisis/...404MAINIDX.pdf
Too Fast TOO FURIOUS
Welcome!
suspension: either coilovers or lowering springs + konis if you are concerned about the stock shocks. however, some lowering springs with moderate drop are fine for stock shocks.
wheels: 19s are perfect, IMO. you can run staggered or non-staggered. 19x8 to 19x10 with 30mm-35mm offset.
lip kit: just with front aspec lip is fine, but might look weird without rear lip. sideskirts aren't that noticeable.
blacked out headlights: lots of members have done this mod. either DIY or have a shop or a member to help.
is your 04 automatic or manual?
wat
Thanks for the replies haha. Glad to see that the responses arent all viscious and bloodthirsty lol.
My car's automatic. I'm really tempted to drop the car like 1.5-2" and get the lip kit and worry about the rims a little later. After seeing jorge68's tl I've been inspired to do it haha.
LIST/RAMEN/WING MAHSTA 짱
AZ Community Team
Received 7,770 Likes
If your drop is ~1" - 1.5" you *might* be able to run the stock shock and have them wear pretty close to normal.
Wheels are a personal choice for style. With the '04 AT, you have ALOT of choices available that will fit just fine. 19's for looks, 18's for performance.
Originally Posted by Bearcat94
If you drop the car that much, you'll probabaly wear out the stock shocks pretty fast. For ~2", it'd be easier and cheaper in the long run to get Springs/Shocks or a Coil-Over right off the bat.
Checkout the groupbuy going on. The first thing I did was buy the full A-Spec underbody spoiler kit. The car looks awesome and more complete with it.
The price is fair and includes shipping, which was a steal for me in Cali. This is the first mod I did.
Wheels will take some thinking. Do you want looks, performance, or both? A lot of people go for the accessory 18" wheels or the A-Spec wheels. It's a tough decision with many factors involved.
Check out the "performance" section to see what others are doing e.g. TB spacer, Intake, exhausts.
Also, check out how others have upgraded their audio systems.
The nice thing is that we have a pretty active community with lots of pix of what others have tried.
soupi
14
11-15-2015 11:15 AM
