So does this work or should I just avoid it???
Hey guys I've seen a few threads on here about using(soldering) a .24 ohm resistor in your 2004-2008 TL relay under the dash in the fuse box if your wanting to run LED's for the front and rear turn signals. Is this still working out just fine for anyone? Or should I avoid messing with this all together and just get the 4 separate resistors you connect to each light? It appears that about half the ziners run into issues right from the start and some have no issues at all and the rest it'll work for a little while but start to give em problems. Figured I'd ask the experts. Any updates or advice would be great. Thanks fellas
I just modified my relay last month using a .12 ohm resistor since I only changed my rear signals. Takes less than 3 minutes if you know how to solder. The hardest part was getting the damn relay out...
Apparently some have good experience doing this....me, not so much. I attempted this on a previous TL I had and I will never mess that with relay again. I am experienced with soldering and electronics and for whatever reason it was just not working. It caused my interior lights to do really weird things like flicker, go on with lights switch off etc etc. not to mention the relay is extremely hard to get out and when you do the stupid tabs break. I use the VLED V3 Tritons and the units come with built in resistors....easy.
I wouldn't touch the relay, but thats just me.
I did the relay for myself and some other AZine members. It worked perfectly with a .12 ohm resistor I ordered from digi-key. I think it's a way better solution than resistors at each bulb. It just seems messy that way. If you'd like, you can send me your relay, and I'll happily mod it for you
I've had it done since 2011.
Works perfectly, and yes the relay is very difficult to remove. I think I broke a clip on the side, but no matter - it's held in by so much friction.
That would be cool man.
Thx.
I have v3 triton switchbacks for the front and some other led turn signals for the back.
Even though the v3 tritons come with the built in resistor you can disable it if you want.
Since I have a 0.24 ohm resistor already soldered into my turn signal relay I disabled the internal v3 triton resistor. Everything works as intended with no hyper flash
Are you sure there's no alternative.
A quick search of Ebay brought up these (obviously for the rear turn signals)
http://www.ebay.com/itm/381082870516?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I'm tempted to try them...
I still haven't found the 7443 model for the front turn signals
Red No Resistor Required 7440 CREE LED Bulbs for Front Rear Turn Signal Lights | eBay
Don't come crying back when you realize "you get what you pay for"
The V3 Triton are pretty much top of the line, and with most things top of the line your ROI is minimal vs the second best offer.
As for the rest,
polobunny, as I'm not trying to get the "MOST" lumens from a turn signal, I completely agree that the ROI for these alternate bulbs may work "good enough".
vietx, I'll def. keep this thread updated. It's always nice to know there's some choice out there.
I've had some issues finding Front turn signals as they're the 7443 style. I've only found the equivalent 7440 style (resistor free) on ebay. I was looking through the TLX forum and found these ( WeissLicht LED Turn Signal Bulbs From bimmian.com )
I'm just trying to fig. out if they'll work dual function (parking lights / turn signal). They also read not requiring resistors.
Anyone have any other ideas?
The turn signal bulbs paperboy and I use are very bright, probably closest thing to Tritons.
They're JLC Lightings 40W bulbs.
My 120 SMD ones were pretty bright.
I then tried the "Plasma" ones from Putco because rockstar143 uses them and said they're bright, and ended up returning them because my 120 SMD ones were still brighter.
Then I got the JLC Lighting bulbs, way brighter than my 120 SMD ones.
http://vid136.photobucket.com/albums...ps1ca14ec8.mp4
It's always great when some child posts a douchebag opinion which was never asked for, nor did it help in any way. Did I ask for something as good as the Tritons? I was just looking for a less expensive alternative. I don't need the top of the line bulbs, nor did I say I wanted something equivalent.
That's just always been my principle, "douchebag" or not.
If you find real CREE LEDs though the quality is top notch. While it doesn't guarantee they are true CREE bulbs, at the price I would be led to believe they are.
CREE has been around for 27 years and has a revenue of over a billion a year. Not your typical eBay bulbs.
I bought my front from an ebay member sanlongparts.
http://www.ebay.com/itm/2x-Switchback-992-7440-7443-22-LED-Amber-White-High-Power-Turn-Signal-Light-Bulb-/121271402430?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3c56bfbe
My buddies bought them after I got them to see the brightness in the day and night. Pretty damn good for its price.
But to each their own, I'm sure you'll find people that have bought those and have worked fine for a few months or even longer. I'd say go for it!
Oh I know CREE leds are great, but the diode themselves aren't usually at fault during bulb failures, it's usually poor heatsinks, poor soldering, and overall poor quality of everything else on the bulb. it's the whole "You're only as strong as the weakest link", sure CREE leds will last forever because they're of great quality but how about the PCB board on which the LED is soldered? If that fails, you're SOL.
I've had a CREE 9005 30W bulb fail because the driver came unsoldered.
Hey guys I took a chance and bought these...let me know what you think
http://www.ebay.com/itm/251793572787?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I posted a video on YouTube of what they look like and here's that link as well.
I'm using 6ohm 50w resistors for now but might try the .24 resistor method because I want to run LEDs in the front as well.
All opinions are welcome...even if they aren't friendly haha. Thanks acurazine familia
2X Switchback 992 7440 7443 22 LED Amber White High Power Turn Signal Light Bulb | eBay
Well if these don't hold up then maybe I'll go this route... Idk tho...those Tritons are so expensive. 😳😳😳
If you guys are looking for an alternative to VLEDs, really would like to see someone try these out.
7443 XB LED CREE XB-D Headlight marker turn signal bulbs blinkers
They have an option for switchback and resistors for extra, that's not mentioning your buying from a forum vendor and get a two year warranty.
I went with some Red's from Ebay, posted a video in this thread.
https://acurazine.com/forums/third-g...thread-921929/
And to stay on topic, I've done the mod the OP was asking about, I have VLED's out front w/o resistor and the Ebay LED's in the back w/o resistor, no hyper-flashing and everything works nicely.
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
IndycarFaster
Sep 11, 2015 02:52 PM
