Slight Brake Squealing on '06 TL MT
I just got my 06 TL MT for more than a week. I did the Manual Tranny Fluid change to the GM one and it definitely fixed the 3rd gear problem. Now I notice some squealing noise most likely coming out from the front Brembo brakes. The squealing noise is not always there, just sometimes. When I bought the car, the rear rotor and pad have been replaced. I checked the front pad and it still have some life on it (roughly 5-6mm). So I am kinda wondering what I should do for it. Any suggestions?
I did checked some of the old threads and it looks like this is common among Brembo brakes on TL-S and TL MT.
I have this problem too. I had Acura replace the pads to be safe when I first got the car (free lul) and it didn't help. Over time it went away. I recently replaced em with Hawks and its doing it again. Maybe its just new pads? I noticed when its all warmed up it doesn't squeal one bit but when its cold or if the brakes sit for too long without being applied it squeals. I think you just need to apply brake anti-squeal and let it sit long enough before you slide the pads in. Someone correct me if I'm wrong or if there's another solution.
http://www.heeltoeauto.com/pitboard/?p=499
http://www.zeckhausen.com/bedding_in_brakes.htm
I had a similar issue with my previous 05 and it was actually the master brake cylinder/drum. There was very slight warping, and Acura tried to slightly shave it down which would get rid of most of it but it would come back a little more this time. Did that a few times but had to replace... ended up blowing out a couple calipers - they shaved so much off there was hardly anything left!
Moral of the story for me is if that does end up being the issue, just get them replaced.
if you got hawk pads , try bedding them in ...
emailnatec
29
Sep 28, 2018 04:27 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
