Slack in steering wheel
Anybody here have any type of slack in their steering wheel. What I mean is when you turn the wheel it takes a while for the car to react. My steering isn't as sensitive as it used to be and the slack is getting worse. ON the highway I can move the wheels in either direction about an inch before I get any kind of reaction. ANother way to tell is when I'm at a standstill and try to turn the wheel back and forth gently. You feel the slack before the power steering kicks in. Maybe a steering box problem?
You definately have some sort of a problem with your steering. There should be almost no slack or play in the TL's steering. It's not a good idea to move the steering wheel when the car is sitting still and doing so puts strain on all the steering components. Have your steering checked and compare it to another TL at the dealer just to be sure.
Team Anthracite Member
Bad news for you sounds like - the one thing about my '04 TL that differs from my wife's '02 is the steering. VERY sensitive and reacts immediately. I actually hate driving her '02 now because comparing the two, it feels as though her power steering is gone - it is very slow and stiff.
Get it check it out.
wow, i'm not going crazy. i have the same issue, in addition to the vibration. it all started happening around 3,000 miles (both vibration and slack in their steering wheel at the same time). i told my service manager and dsm, no idea what is going on.
My steering is extremely direct and responsive. There should be virtually no free play. Either you have a defective rack and pinion unit or your tires are underinflated. Go check your tire pressure to ensure they are 32 psi all around if you have a 5AT or 35 psi with the 6MT. With the recent cold weather, you may be down several pounds which will make the ride cushy and the steering somewhat "vague". Fill the tires up and then report back to us. Good luck.
dsc888
dsc888
Registered Member
Here's a hint, people. You should never turn your wheels when the car is not moving. This puts a great deal of stess on steering components and can lead to a looseness in the steering wheel. Avoid this habit (you'd be amazed at how many people do this).
rockyboy
12-06-2022 02:29 PM
EvilVirus
12-10-2015 07:38 PM
