Side mirrors in Reverse
Old May 7, 2008 | 03:39 PM
FlyinLowTL's Avatar
Ok, so everyone here knows that when you put your TL in Reverse, the side mirror slants so that you can see the ground - presumably the curb when you are backing up. What I want to know is - why is this happening (at least on my 05 TL Navi) to just the left side? I was sure that at one point the right side did it once or twice, but now it's just the left side.
I would prefer that the right side did it because when I parallel park on the right side of the street (per normal US Standards), I would like to see the curb so that I don't scuff my wheels up.
Is this a preference ? Is it automatic - having something to do with the direction the wheel is turned?
The manual says nothing about it whatsoever, so naturally, i gotta turn to the expos at Acurazine...Thanks in Advance!!
-Jay
Old May 7, 2008 | 03:41 PM
timmahh's Avatar
it's me, Alan Rickman.
Change the mirror switch to the right side... bam!
Old May 7, 2008 | 03:42 PM
FlyinLowTL's Avatar
Fleshy - you are the man.
thanks!!!
Old May 7, 2008 | 03:47 PM
don5504's Avatar
I wish both sides would do it when left in the middle position.
D
timmahh's Avatar
no problemo; be prepared for some people to respond.. "USE THE SEARCH BUTTON!!"
But, since this thread is already open.. :
- You can roll the windows down & open the sunroof by using your keyfob [unlock, unlock + hold until you have them at the desired level]
- You can roll the windows down & up and open & close the runroof by using your key in the door: Lock -> Lock + Hold to initiate roll up; Unlock -> Unlock + Hold to roll down; again let go when it's at the level you want
TeknoKing's Avatar
now if only both side mirrors closed-in when you exitted that car, now that will be sweet
Old May 7, 2008 | 03:55 PM
08WDP's Avatar
Thats exactly what i was thinking, my cousin's 07 escalade does that, its so sweet if you have small or stuffed garage or in tight parking spots.
Old May 23, 2008 | 11:53 AM
Slvr_Surfr's Avatar
im confused, is it either the left or the right side mirror that tilts down or both when in reverse?
Old May 23, 2008 | 11:57 AM
TeknoKing's Avatar
^ only one at a time.
O8AcuraTL's Avatar
It's either/or. You'll have to manually select which side by clicking on the mirror button.
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
