Shaking
Old Aug 12, 2019 | 11:59 PM
Kimichami's Avatar
Shaking
05 acura tl,timing from acura,spark plugs from acura,did all d seals no check engine,d car shakes specially when is cold
Old Aug 13, 2019 | 12:02 AM
csmeance's Avatar
Check your engine mounts, usually the side mount is in 2 pieces and the same with the front with wear and tear and also aging rubber. Just be aware when the TL is cold, the engine is programmed to rough slightly rough to warm up the catalysts faster to reduce emissions so some roughness is normal.
Old Aug 13, 2019 | 12:04 AM
Kimichami's Avatar
Shaking
K i know my upper transmission mount is bad,im going to replace it and d two bottom ones too
Old Aug 13, 2019 | 12:05 AM
Kimichami's Avatar
Shaking
I already replace all. Engine mounts exept d transmission mounts
Old Aug 13, 2019 | 12:17 AM
csmeance's Avatar
If you put the car in Neutral and the vibration goes away then the trans mounts are def. the issue.
Kimichami's Avatar
Shaking
K im going to do that,thank u
ericcdong
Jun 25, 2015 05:51 PM
3.5RLv-tec?
1G RL (1996-2004)
Jan 13, 2015 11:45 PM
lkoszela
Apr 3, 2011 11:02 PM
clinoak
Apr 15, 2010 08:00 PM
