Shaking
Check your engine mounts, usually the side mount is in 2 pieces and the same with the front with wear and tear and also aging rubber. Just be aware when the TL is cold, the engine is programmed to rough slightly rough to warm up the catalysts faster to reduce emissions so some roughness is normal.
Kimichami (08-13-2019)
If you put the car in Neutral and the vibration goes away then the trans mounts are def. the issue.
