Service A23?
Old 12-17-2013, 01:28 PM
hostile429's Avatar
Service A23?
ok az i googled searched for a a23 service being that it popped up and this thread popped up on the mdx part of az
https://acurazine.com/forums/1-2g-mdx-2001-2013-166/mpg-mdx-800855/
does it apply the same for the tl? has anyone had a a23 service done? could anyone post part numbers ie for filters and such so i can acquire
Old 12-17-2013, 06:09 PM
THTL's Avatar
A23 is for :
A : Change engine oil
2: Replace air cleaner element. Replace dust and pollen filter. Inspect drivebelt
3: Replace Transmission fluid.
The following 2 users liked this post by THTL:
GKinColo08TL (12-17-2013), TLtrigirl (12-18-2013)
Old 12-18-2013, 11:38 AM
fordcourier72's Avatar
Oil Life Message What to Do
15% SERVICE DUE SOON
Plan to take vehicle in for
scheduled maintenance.
5% SERVICE DUE NOW
Take vehicle in now for
0% SERVICE PAST DUE
(Mileage past due is also shown)
Service is overdue.
Take vehicle in now
for scheduled maintenance.
Symbol What It Means
A - Replace just engine oil.
B - Replace engine oil and oil filter.
Also inspect various systems and components
(see applicable service manual for details).
Number What to Do
1 - Rotate tires, and check tire pressure and condition.
2 - Replace air cleaner element, check drive belt,
and replace dust and pollen filter.
3 - Replace transmission fluid and transfer fluid (if equipped).
4 - Replace spark plugs, replace timing belt (if equipped),
inspect water pump, and inspect valve clearance.
5 - Replace engine coolant.
6 - Replace rear differential fluid (if equipped)
LoveMyTL-S (12-18-2013)
Old 12-18-2013, 11:40 AM
3G TL/2G MDX Owner
TLtrigirl's Avatar
codes are basically the same across the line up.
Old 12-18-2013, 11:47 AM
Here is the check list for the B - service
Check front and rear brakes
Check pads and discs for wear (thickness), damage, and cracks.
Check calipers for damage, leaks, and tightness of mounting bolts.
Check parking brake adjustment
Check the number of clicks (7 to 9) when the parking brake lever is pulled with 196 N (20.0 kgf, 44.1 lbf) of force.
Check steering linkage.
Inspect tie-rod ends, steering gearbox, and gearbox boots
Check fluid lines for damage and leaks.
Inspect suspension components
Check bolts for tightness.
Check condition of ball joint boots for deterioration and damage.
Inspect driveshaft boots
Check boots for cracks and boot bands for tightness.
Inspect brake hoses and lines including VSA lines
Check master cylinder and VSA modulator-control unit for damage and leakage.
Inspect all fluid levels and condition of fluids
Engine coolant
Clutch fluid
Manual transmission fluid
Automatic transmission fluid
Power steering fluid
Brake fluid
Windshield washer fluid
Inspect exhaust system
Check catalytic converter heat shields, exhaust pipes, and muffler for damage, leaks, and tightness.
Inspect fuel lines and connections
Check for loose connections, cracks, and deterioration; retighten loose connections and replace damaged parts.
Old 12-18-2013, 05:49 PM
5th Gear
323's Avatar
what is A12?
Old 12-18-2013, 07:02 PM
3G TL/2G MDX Owner
TLtrigirl's Avatar
^^uh...see post #3.
Old 12-19-2013, 12:35 PM
hostile429's Avatar
thanks i was a little bit confused but that cleared it up
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
thegipper
09-28-2015 01:01 PM
jmaxima03
09-27-2015 10:22 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: Service A23?
