Service A23?
Service A23?
ok az i googled searched for a a23 service being that it popped up and this thread popped up on the mdx part of az
https://acurazine.com/forums/1-2g-mdx-2001-2013-166/mpg-mdx-800855/
does it apply the same for the tl? has anyone had a a23 service done? could anyone post part numbers ie for filters and such so i can acquire
Oil Life Message What to Do
15% SERVICE DUE SOON
Plan to take vehicle in for
scheduled maintenance.
5% SERVICE DUE NOW
Take vehicle in now for
0% SERVICE PAST DUE
(Mileage past due is also shown)
Service is overdue.
Take vehicle in now
for scheduled maintenance.
Symbol What It Means
A - Replace just engine oil.
B - Replace engine oil and oil filter.
Also inspect various systems and components
(see applicable service manual for details).
Number What to Do
1 - Rotate tires, and check tire pressure and condition.
2 - Replace air cleaner element, check drive belt,
and replace dust and pollen filter.
3 - Replace transmission fluid and transfer fluid (if equipped).
4 - Replace spark plugs, replace timing belt (if equipped),
inspect water pump, and inspect valve clearance.
5 - Replace engine coolant.
6 - Replace rear differential fluid (if equipped)
5% SERVICE DUE NOW
0% SERVICE PAST DUE
Service is overdue.
Take vehicle in now
Number What to Do
Here is the check list for the B - service
Check front and rear brakes
Check pads and discs for wear (thickness), damage, and cracks.
Check calipers for damage, leaks, and tightness of mounting bolts.
Check parking brake adjustment
Check the number of clicks (7 to 9) when the parking brake lever is pulled with 196 N (20.0 kgf, 44.1 lbf) of force.
Check steering linkage.
Inspect tie-rod ends, steering gearbox, and gearbox boots
Check fluid lines for damage and leaks.
Inspect suspension components
Check bolts for tightness.
Check condition of ball joint boots for deterioration and damage.
Inspect driveshaft boots
Check boots for cracks and boot bands for tightness.
Inspect brake hoses and lines including VSA lines
Check master cylinder and VSA modulator-control unit for damage and leakage.
Inspect all fluid levels and condition of fluids
Engine coolant
Clutch fluid
Manual transmission fluid
Automatic transmission fluid
Power steering fluid
Brake fluid
Windshield washer fluid
Inspect exhaust system
Check catalytic converter heat shields, exhaust pipes, and muffler for damage, leaks, and tightness.
Inspect fuel lines and connections
Check for loose connections, cracks, and deterioration; retighten loose connections and replace damaged parts.
Engine coolant
Clutch fluid
Brake fluid
