Scuff Marks
Old Apr 22, 2008 | 07:46 PM
S L I C K's Avatar
Slicker Than Your Average
Scuff Marks
Anyone know how to remove black scuff marks from the interior of a car w/o causing any damage?
Old Apr 22, 2008 | 08:33 PM
psychodoc's Avatar
I'd be interested in any help with this too . . .
Old Apr 22, 2008 | 09:06 PM
csmeance's Avatar
it depends where they are, if they are on the plastic portions, first try a solution of woolite and water, 1 part woolite to 5 parts water. This will clean up the plastic. If it's on the leather, use a 1:6 ratio, so that it is more diluted. Follow up with some 303 aerospace protectant.
Old Apr 22, 2008 | 09:13 PM
jeowen's Avatar
yea..the 303 or alot of us swear by Maguires Vynal/Rubber cleaner, for dash , and Maguires leather conditioner for the seats- the woolite and water is a must!!!
Old Apr 22, 2008 | 11:39 PM
Bearcat94's Avatar
AZ Community Team
If it's really stubborn AND depending where it is, Mr. Clean Magic Eraser might do the trick.
Old Apr 23, 2008 | 07:47 AM
S L I C K's Avatar
Mine are on the plastic near the foot pedals.
Old Apr 23, 2008 | 07:52 AM
psychodoc's Avatar
Thanks for the info!
Old Apr 23, 2008 | 07:53 AM
vinnier6's Avatar
yea, i have some scuffs down low by where the seatbelt hangs by the seat and the door...the black plastic was scuffed up just sitting on the showroom floor....i have tried everything i have in the garage...nothing works....its like a scratch in your paint....you can soften it up a bit, but your not going to get rid of it...
Old Apr 23, 2008 | 08:10 AM
Tripnbeats's Avatar
uuuuh scuff marks on the plastic cannot be removed unless u go to an upholstery shop n have it fixed.....if they even fix them....if they are just light scuff marks and they look like rubbers been left behind from a sneaker a damp rag and some kinda conditioner Im sure would remove it.
Old Apr 23, 2008 | 11:18 AM
007TL-S's Avatar
Be kind to us truckers !
spray some WD-40 on a paper towel, ...quick and easy , then when the stain is just gone just go over with a damp cloth!
Old Apr 23, 2008 | 11:33 AM
TeknoKing's Avatar
Since we are on the topic, my question is dealing with paint though...
After a few car washes, I have a few what looks like sap or tar marks on the roof and side skirts, I don't know, looks like embedded dirt.
When I try to remove it with a wet towel, it doesn't really budge....with compound it goes off easily, but I remember, once in the car wash a guy wet a towel into some liquid, and with one swipe took everything off....what's the liquid? I have same marks on the driver side door, behind the handle.
Freaken WDP
Old Apr 23, 2008 | 12:07 PM
Tripnbeats's Avatar
prob liquid clay or tar remover
Old Apr 23, 2008 | 12:09 PM
vinnier6's Avatar
wd40 will take tar off just as easy as anything else will....
Old Apr 23, 2008 | 12:11 PM
TeknoKing's Avatar
is wd40 safe on the paint?
Old Apr 23, 2008 | 12:17 PM
Tripnbeats's Avatar
wd40 is a degreaser id say no. any cleaner takes the wax layers off with no mercy so once u do clean it make sure u get ur wax out n re-apply
Old Apr 23, 2008 | 06:12 PM
S L I C K's Avatar
I ended up using a simple soft white eraser and it worked like a charm!
Old Apr 24, 2008 | 02:43 PM
Acura Diver's Avatar
I had this problem as well and I used my claybar to remove it. It worked well with no damage to the car!
Old Apr 24, 2008 | 03:37 PM
csmeance's Avatar
You can fix this by using a hair-drier that gets really hot or a lighter, basically you melt the plastic slightly and fill in the hole. Don't try tis if you have no expierence with fixing this type of stuff. Also 303 helps hide them for a bit.
dirko
Oct 1, 2015 08:45 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 08:57 PM
Sep 14, 2015 10:48 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
