On a scale from 1-5, what would you rate Acura's prestige level?
#124
Registered Bike Offender
What do you mean? Yes, I agree that the powertrain in a vehicle is the absolute determination of prestige level, but they're fitting 9 gears into a transmission with paddle shifters! 9!!! PADDLE SHIFTERS! And they're finally offering a high output 2.4 with reasonable fuel economy! I'm really impressed that they can build an engine bigger than a Dodge Viper engine with better fuel economy, and stuff 9 gears down there. Besides man, I thought that everyone knew monkey urine has more protein than a carrot on a snowman's nose. Unless bringing fourteen ducks to a rock show in Japan stops you. You can't see are then if when going up to down bound sound ground mound when to able are can.
GRAF-FITI (01-17-2014)
#125
For what it's worth, packing a million gears into an auto which is usually just a different shifting strategy (applying more than one gear at a time for a split) is for mpg, it has little to no effect on acceleration. It puts you closer to a CVT sort of.
#126
Well I think you might not understand because you still haven't found a square strawberry inside the HDMI cable in the light fixture. It took me a while too, but eventually a purple midget made me a glass of juice and I was able to see the Twinkies on his overalls.
I didn't realize that the gearing was mostly for mpg: I figured that there must also be some sort of power delivery advantage as (at least, the way I understand it) with that many speeds, you theoretically have access to the power band at a larger selection of vehicle speeds. I can probably rebuild a standard trans, but I still have no idea how a torque converter works.
The CVT has infinite gears. And they pack infinite gears into a metal box under the hood. Now THAT'S prestige. I'm buying a fourth gen Altima.
Anyway, I think our transmission conversation is a little off topic. I'm surprised someone hasn't rebutted my prestigious claims of naked ferris wheel rides and monkey urine. I'm ready with counter arguments...
![what](https://acurazine.com/forums/images/smilies/what.gif)
