Is it safe to get the engine machine cleaner done?
Here's the thing. I bought a used 04 TL and wanted to get some maintenance out of the way since I don't know if the previous user took care of the car.
Is it safe to have an independent mechanice or some place like Jiffy Lube run this machine that's supposed to flush your engine oil and clean the sludge?
After that I'm going to have the tranny fluid and filter replaced, breaks bled and refilled and then the coolant. Not all at once though one after the other. Oh yeah and air filter. The spark plugs last.
I wouldn't let one of those Jilly Lube workers sit in my TL let alone work on it.
(Dont mean to offend anyone, heard some bad stories and had a bad experience)
Go to someone you know and trust or do the work yourself.
Flush brake fluid every year- good plan!
Coolant- not required till 5 years
Trans- read owner manual for proper procedure of drain refill x 3
Air filter- once a year
Cabin air filter- once a year
To clean the engine- read gen2 thread- Seafoamed the Ol TL, add 1 can of Seafoam cleaner to crankcase- run 5 to 15 minutes and change oil- will remove crud
Same stuff goes in intake vac line and gas tank, works like magic~
Originally Posted by McKulit
That was quick. Thanks guys. I wish I can do it myself but I don't have the space. Okie Dokie. I'll find a good indy shop around.
Change Engine air filter
Change Cabin Filter
3X drain/refill of transmission fluid
Brake Fluid drain and fill
Change the plugs (after seafoam treatment ONLY)
When you say 3X drain/refill of transmission fluid
Is this done the same day? I don't get it. Is it drain .... fill .... run car .... then repeat process all over? (scratching my head)
correction- per azine and acura book
Warm car with 15 minutes freeway drive
drain 3 qts- thats all it will give up at a time of 7.something total in system
refill 3 qts
DRIVE 5 minutes, drain 3 add 3 drive 5 repeat 3 times
for 9 pts total used in process
use ONLY Honda ATF- same as acura but cheaper at honda dealer
Seafoam is done standing next to the car and inthe gas tank- you have room for that!
Jiffy may do the trans the way you want if you bring fluid- easy to drive in drive out there
versus dealer uses a rack- time consuming
Can be done by most at home with ramps $30
refill 3 qts
Thanks guys I really appreciate the input. I know I should read the owner's manual for some guidance but unfortunately since I bought the car used it didn't come with it. I just saw the link to the manuals from the garage link, I'm going to start reading.
Seafoam or whatever fuel system cleaner you like should be a part of regular maitenance, like every few months with the winter blend fuels coming out soon
Keeping the injectors spraying nice (there are shops that clean and flow bench tune injectors for race cars,) and the valves sealing and piston top clean for full combustion-
thats all reallly important!
Maybe Petrol is cheap above the border, but here- I try to get all the economy out of the car I can for regular driving. Thats my carbon footprint offset for track days
Sep 17, 2015 09:01 PM
Sep 15, 2015 06:44 PM
