rust spot on drivers mirror
Few weeks ago I noticed that a small rust spot showed up on the drivers mirror. I tried to use windex (typically I use it to clean mirrors and windows), but the spot is still there and I could not remove. Any way to remove it? Is this under warranty issue? My car has only 10k. I will follow up with a picture once I get back from work.
thanks
thanks
If it's truly rust, try a little CLR on it (if you have some around). It is supposed to remove surface rust deposits on stuff like chrome and ceramic plumbing fixtures, it should work fine on your mirror (I'd be careful with it around painted surfaces, however). Once you get it off, you should be able to determine whether or not the rust originated there or possibly somewhere else.
If it looks like something on the car is actually rusting, sounds like a trip to the dealer would be in order.
^ I don't know if I would try this and possibly mess things up further. Just take it to the dealership and have them take a look at it. If it really is rust and is a manufacturer defect, it should be covered
Originally Posted by ajdigerati
I had a similar issue. It may just be iron dust. Try clay barring it. Worked for me in a few areas.
My suggestion was for if the spot was on the mirror (glass) itself, just to be clear.
thank you guys for help. I forgot to take any pictures. My dealer is only 5 miles away and i actually have to go there tomorrow for oil change and tire rotation so i will tell them about the mirror.
rockyboy
Aug 4, 2024 10:35 AM
guitarplayer16
Nov 29, 2015 02:03 PM
sockr1
Oct 1, 2015 01:31 AM
