Rubbing noise while braking
Old Sep 2, 2005 | 01:21 PM
labrador26's Avatar
Has anyone had an annoying rubbing sound that comes from the rear driver side wheel while braking? The sound can be heard from 15MPH down to about 5MPH then it goes away. I have an '04 TL with 15K miles. As it will be warranty work, I'm not too worried but want to ensure that it's fixed appropriately the first time. Thanks for your help.
Old Sep 2, 2005 | 08:58 PM
Road Rage's Avatar
Not a Blowhole
I have not, but you could have a partially stuck caliper, glazed pad, damaged rotor surface, etc. Unusual that it is in the rear, which is lightly loaded from a brake perspective. Let us know the dealer's diagnosis.
RR.
Old Sep 3, 2005 | 03:58 PM
pettydw's Avatar
A potential cause may be a pebble trapped at the leading edge of the caliper. It is easy to take a look thru the wheel spokes. Otherwise, a few panic stops may clean off whatever is on the pads or rotors. It does not hurt to cycle the ABS every now and again, just do it in a safe manner.
Old Sep 3, 2005 | 05:05 PM
labrador26's Avatar
The dealer diagnosed it as a warped rotor. They ordered the new rotor and machined the existing one a bit so I could drive the car until the part comes in. If I'm not mistaken, I have read complaints about the rotors in other posts. As this one is the rear, I hope this isn't a sign of things to come.
Old Sep 5, 2005 | 02:10 AM
mojo risin's Avatar
Relax Dog. Give the dealer a chance to help you. Its sounds like they are taking care of you.
Old Sep 5, 2005 | 10:48 AM
Neorick's Avatar
Had the same issue...dealer replaced add four rotors....
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
jliu6789
Sep 8, 2015 08:02 PM
