Royal purple auto transmission fluid?
So I just bought my 2006 acura tl. It has about 96,000kms. The ATF looks brown to dark brown. I am thinking about putting royal purple synthetic tranmission fluid in it. I had it in my 2000 honda accord and it's good stuff. What do you guys think?
Just an FYI-The trans fluid is dyed red to distinguish it from other fluids and it will change color after a period of time which is perfectly normal.
The Kinetics of Bleu
There is a thread in the 3G garage on the drain/refill procedure in which he (Road Rage) used Amsoil ATF and supposedly it is a suitable relacement for Z1. I am not sure if Royal Purple will work for our application. It also says that with the Amsoil shifts are firmer which usually means less wear on clutch packs. I am in the same boat and think I am going to go with Amsoil ATF. I will post the link if I find it..
:EDIT: here it is
https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
:EDIT: here it is
Thanks man I appreciate your help, just be nicer next time and it's all good. Hey my bro had an idea of using the stock intake and just attaching a k&n filter on it, that way your not really modifing the natural aspect of the acura engine...what do you think?
AZ Community Team
Received 7,771 Likes
With the problems Acura has had with Trannies, I'm reluctant to use anything but Acura/Honda fluid.
If the trans goes bad, it's on them.
mada51589
05-03-2022 08:54 PM
