Rolling code garage door opener....
Old Apr 29, 2004 | 08:19 AM
SilverJ's Avatar
Will it work with the tl? I know I could not get it to work with my 01-cls...
Just wondering before I invest the time.
Old Apr 29, 2004 | 08:27 AM
TBone2004's Avatar
Team Anthracite Member
Yes, works fine. Ended up calling the Homelink# cause I think the instructions in the manual were off. The quickstart guide I think explained it better.
Old Apr 29, 2004 | 08:32 AM
6speed's Avatar
Worked for me. The small guide explains it well.
Old Apr 29, 2004 | 09:30 AM
bollywood21's Avatar
You can use this url for rolling code garage door openers:
I have rolling codes and it works fine:
http://www.homelink.com/program/rolling.html
Old Apr 29, 2004 | 09:32 AM
SilverJ's Avatar
quickstart?
Is that in my auto manual?
Old Apr 29, 2004 | 09:39 AM
Exclamation Manual was not helpful
Philly in the house!!
Don't use the manual, you will get frustrated. Use the url i inserted or call home link and go thru the prompts for rolling codes.
Bollywood
Old Apr 29, 2004 | 02:04 PM
SilverJ's Avatar
hmm
I downloaded the manual for the homelink---do I have to do the programming section as well as the Rolling code programming section?
Old Apr 29, 2004 | 02:14 PM
Dude :rocketwho
You have to do both. Its pain in the ass, setting your remote, blinking light on the HL, pressing a button back at the garage device, and then hurrying back to your car to the set the home link again.
Trying have to do it on for two cars with a 3 garage door openers :devil: !!!
Old Apr 29, 2004 | 02:35 PM
SilverJ's Avatar
Originally Posted by bollywood21
Dude :rocketwho
This is what I got..
Programming
Note: For best results, replace the battery in the handheld transmitter with a new battery before programming. If your
garage door opener receiver (located in the garage) is equipped with an antenna, make sure the antenna is hanging
straight down.
1. For first-time programming, press and hold the two
outside buttons until the indicator light begins to
flash (after 20 seconds). Release both buttons.
Note: Some vehicles may require the ignition switch
to be turned to the second (or “accessory” ) position
during the programming process.
2. Hold the end of your handheld transmitter between
1 and 3 inches away from the HomeLink surface
(located on your visor or overhead console) keeping
the indicator light in view.
3. Using both hands, simultaneously push the
handheld transmitter button and the desired
HomeLink button. DO NOT release the buttons until
step 4 has been completed.
4. Hold down both buttons until the indicator light on
the HomeLink Wireless Control System flashes, first
slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light
indicates successful programming of the new frequency signal.) To activate the garage door or other programmed
device, press and hold the HomeLink button—releasing when the device begins to activate.
5. To program the remaining two buttons, follow steps 2 through 4.
Rolling Code Programming
Rolling code garage door openers which are “code-protected” and manufactured after 1996 may be determined by thefollowing:
• Reference the garage door opener owner’s manual for verification.
• The handheld transmitter appears to program the HomeLink Universal Transceiver but does not activate the garage
door.
• Press and hold the trained HomeLink button. The garage door opener has the rolling code feature if the indicator light
flashes rapidly and then turns solid after 2 seconds.
To train a garage door with the rolling code feature, follow these instructions (the aid of a second person may make the
training quicker and easier):
1. Locate the training button on the garage door opener motor head unit.
Exact location and color of the button may vary by garage door opener
brand. If there is difficulty locating the training button, reference the
garage door opener owner’s manual or please visit our Web site at
www.homelink.com.
2. Press the training button on the garage door opener motor head unit
(which activates the “training light”). Note: Following step 2, there are
30 seconds in which to initiate step 3.
3. Firmly press and release the programmed HomeLink® button. Press and
release the HomeLink button a second time to complete the training
process. (Some garage door openers may
require you to do this procedure a third time
to complete the training.)
The garage door opener should now recognize the HomeLink Wireless Control System.
I guess if I do all these steps I should be in business...
My remote garage door opener only has one button so I assume I would only have to program one button and it will open and close the garage door.
Old Apr 29, 2004 | 04:54 PM
Stewie's Avatar
I got my rolling-code garage door opener to work on my homelink in my 98 CL but it was a huge pain in the ass as I recall.
mada51589
Jan 9, 2025 04:40 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
CadiGTi
Sep 14, 2015 06:37 PM
HeloDown
Sep 8, 2015 06:51 PM
