Rocks in Door sills, how to clean?
Old Jul 10, 2012 | 07:32 PM
paperboy42190's Avatar
Just curious, how do you guys clean your door sills? Seems like a lot of small rocks get stuck in between the little gap. I don't suppose the black frame part is removable? That would definitely get the rocks out.
Old Jul 10, 2012 | 10:49 PM
McCollins23's Avatar
Chapter Leader (Midwest Region)
A toothbrush or a stiff bristled paint brush is what I use, if I think it's what you are talking about.
Old Jul 11, 2012 | 08:05 AM
^what he said.
I also use a shop vac
Old Jul 11, 2012 | 09:04 AM
^^^ What he said.
Old Jul 12, 2012 | 04:00 AM
ohseven's Avatar
^^^what they said absolutely right small brush and vac
Old Jul 12, 2012 | 07:15 AM
LoveMyTL-S's Avatar
ShopVac for the win. You can also used a small soft paint brush or a rubber detailing tool.
The title is a little misleading, as I thought you wanted to clean the rocks.......
Old Jul 12, 2012 | 10:07 PM
cpm06wdptl's Avatar
The black frame can be separated from the aluminum part. After you take it off of the car and flip it over there are tabs that you can pry up with a screwdriver and then take the two pieces apart. I did it this way because, just like you, the little pebbles and stuff really annoy me
Old Jul 12, 2012 | 10:24 PM
SilverSVT's Avatar
Praise the lord, I am not alone! I was thinking of turning my compressor on and the blow gun, but the paintbrush idea will probably require less vacuuming afterwards.
Old Jul 13, 2012 | 12:18 AM
^best post! thanks, it'd be much cleaner if I could remove the black frame. when I do work on my car I do it right and perfect.
BoricuaTL
Apr 8, 2016 01:08 PM
obert
Dec 14, 2015 11:36 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
EE4Life
Sep 11, 2015 10:13 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
