RL BBK project almost ready to go. Need that bracket though.
Old Feb 23, 2013 | 07:34 PM
  #161
fsttyms1's Avatar
Originally Posted by 94eg!
Who is talking about a 2000 TL?
No one (but that is drive with a type-s motor, and a 6 speed conversion and soon to be fully built 3.7 ) I was just looking at the other Acura vehicles looking for a larger MC bore size , though it might explain why ive always had great braking
Old Feb 23, 2013 | 08:38 PM
  #162
fsttyms1's Avatar
A larger rear brake kit "could" be benificial from a bias stand point. But the major problem in adapting a brembo 2 or 4 piston caliper would be the thickness of the rear rotors. All cars with rear brembos have ventilated rear rotors. These are over twice as thick (9mm vs 20mm). Try to adapt that to a solid disc Honda rotor and you might just drop the pads out of the caliper as they wear down.
So then you might think, lets step to a ventilated rear rotor. Again now the theory of performance comes into play. A vented rotor is gonna be a bit heavier. And as we all know, un-sprung rotating mass is the ultimate enemy of performance. Plus, the rear brakes do so little work on a FWD, it's kinda pointless to begin with.
Honestly, I would still like to see someone put in the effort to put STI rear calipers onto one of these. BTW: The 04-08 Sti caliper is really the best option. The piston is slightly smaller than the TL's rear piston, which makes the prospect of a larger rear rotor more practical.
04-08 TL Rear caliper & Rotor
04-07 STI rear caliper & Rotor
Interestingly, the 2G CRV has a rotor roughly the same diameter as the STI, with the same hub-register, bolt patern and similar install height as the TL. Perhaps if the internal drum is the same diameter as the TL (170mm), these might work on the TL with caliper adapter bracket.
Wonder if we can get the 350Z Track rear rotor to work with the STI caliper or 350z rear caliper? Though this is a 14" rotor, which if were to be used i would use the 14" front
It doesnt show the Genesis Coupe with brembos with the Drum in Hub which is a 330mm dia with 20/18mm thickness but it is, Looks like the Equus might too
Genesis Coupe
Equus rear
Old Feb 24, 2013 | 03:24 AM
  #163
HCORD87K's Avatar
RL BBK on 6th gen accord
Wassup this message is for Nva-Av6. My names Eddie, and my email is hcord87@gmail.com. i love the rl bbk upgrade. i just bought the calipers, but obviously need the custom bracket for fitment. I heard you make the best brackets for the setup. I want to purchase the brackets ASAP. Can u please contact me via email again at hcord87@gmail.com. Im a new member so this is the only way to contact you for now. Alright thanks hope to hear u soon. P.S. does anyone know NVA-AV6s direct email? thanks
Old Feb 25, 2013 | 03:07 PM
  #164
swoosh's Avatar
takin care of Business in
I am officially confused....
So is the RL BBK worth it? Is the legend 2 piston caliper worth considering instead?
Will either mess the brake bias?
Will either mess the pedal feel?
Will either increase the stopping distance?
Should we just dump both the ideas and looking into XLR8 Stoptech BBK?
Old Feb 25, 2013 | 03:13 PM
  #165
^i thought it was pretty clear cut.
94eg! proved that the RL calipers will fuck up braking bias.
which equates to longer braking distances.
yes, dump both ideas.
Old Feb 25, 2013 | 03:15 PM
  #166
swoosh's Avatar
^^^ true but what about legend 2 pot calipers...
Old Feb 25, 2013 | 03:59 PM
  #167
fsttyms1's Avatar
I dont think he proved it. He provided specifics of what can happen with BBK's, but Until some one tries it we really dont know how it will effect it.
Old Feb 25, 2013 | 05:00 PM
  #168
I hate cars's Avatar
I've got measured proof of longer stopping distances with the Rotora system which doesn't screw up bias as bad as the Legend calipers does.
Old Feb 26, 2013 | 07:27 AM
  #169
okay, in theory.
Old Feb 26, 2013 | 10:49 AM
  #170
swoosh's Avatar
so basically NO for Legend Calipers and BBK....
guess am getting the RDX caliper covers LOL
Old Feb 26, 2013 | 10:59 AM
  #171
94eg!'s Avatar
#1 Super Guy!
I proved it with math & stuff. The RL brake upgrade alone is a very poor idea.
If you want a fancy brake upgrade, go the Stoptech route. That would be ideal.
Old Feb 26, 2013 | 11:02 AM
  #172
maharajamd's Avatar
You're an auto? Had no idea.
Old Feb 26, 2013 | 11:13 AM
  #173
swoosh's Avatar
Old Feb 26, 2013 | 11:15 AM
  #174
maharajamd's Avatar
Lol. No biggie just didn't know.
Old Feb 26, 2013 | 11:16 AM
  #175
Undying Dreams's Avatar
Calipers sold!
Old Feb 26, 2013 | 11:20 AM
  #176
Right, I enjoyed that you laid out the math on the table.
Old Apr 18, 2013 | 04:00 PM
  #177
ArthurL's Avatar
Well looks like my front pads are already worn so they'll need to be replaced soon. Rear pads are in good shape. With the concern of brake bias coming into play.. should I go with less aggressive pads up front? I have EBC RedStuff pads all around.
Old Apr 18, 2013 | 04:03 PM
  #178
I'd very much enjoy your option as well as poorboy's on these calipers. Does the car stop any less than it did before?
Did one of you measure your stopping distances before swapping?
Old Apr 22, 2013 | 10:31 AM
  #179
ArthurL's Avatar
I did not measure the stopping distance. To be completely honest I do feel the car does stop better than before. Significantly better? No. But then again I don't track my car so I haven't used these to its full potential.
I didn't know much about brake bias until I read this thread. But now I'd like to at least try to get the brake bias back to normal as much as I can with this setup.
Old Jan 28, 2014 | 12:51 PM
  #180
Rozay52410's Avatar
I'm doing the same project on my 01 tl an I just need the brake fluid and new brake pads. Does it matter what brand pads or brand on the brake fluid or just any 05-10 rl front pads?
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
samson_420
Oct 8, 2015 01:47 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
