Resetting the Maintenance Minder
Old Sep 3, 2004 | 02:02 PM
mporter410's Avatar
I just picked up my new 04 TL 6MT Navi and am loving every minute of driving it. I usually do my own oil changes on cars, but am not sure if I will on my TL. My hesitation is in resetting the maintenance minder system after you complete the oild change.
My questions are: Does the maintenance minder reset automatically when you change the oil, or do you have to reset it manually?
If you do have to reset it manually does anyone know how to do it?
Thanks, Mike
Old Sep 3, 2004 | 02:05 PM
rets's Avatar
Moderator Alumnus
Welcome to the forum
http://www.acura-tl.com/forums/showp...73&postcount=4
  • MID won't reset automatically for you
  • If reminder pops up, you could always reset it
  • Besides Oil Life, you cannot reset others unless their reminders pop up. For example, tires rotation or tranny fluid, you cannot reset them until their warning reminders display
Old Sep 3, 2004 | 02:08 PM
mporter410's Avatar
Thanks for the info. I put in a search for this and came up empty.
Old Sep 3, 2004 | 02:11 PM
rets's Avatar
Moderator Alumnus
Try to go Garage, there should be some info out there...
Old Sep 3, 2004 | 02:24 PM
Road Rage's Avatar
Not a Blowhole
rets: Is that also the case if one has an OBDII scanner? When I get a light I will check, but i seem to recall there are "pending" resets. I have the same one AutoZone uses, but then I sprung for the big dog, ther AutoXray 6000. I have been meaning to do some coolant temperature studies - I will have to remind myself. I am also going to do an FFT analysis of the ELS audio system.
Old Sep 3, 2004 | 02:30 PM
rets's Avatar
Moderator Alumnus
RR, please try it and let us know. I remember that Sherlock, one of our members, ever used OBDII scanner to check some info. But I do wish we could find some ways to bypass that MID and reset all reminders anytime we want.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
brboy
Oct 5, 2015 11:34 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
