Resetting auto windows?
Old Jan 29, 2017 | 06:27 PM
Ryan Williamson's Avatar
Hello all,
On occasion, I've been having some trouble with my front passenger side window. The window rolls up fine if you roll it up "manually," however, sometimes when rolling it up with the auto feature, the window only will go up about 3/4's of the way--requiring me to "manually" roll up the rest. This all happened after getting my windows tinted, as the shop did take off the door panels to do so. The shop recommended me to preform a "reset" by holding the switches a particular sequence.
Being the winter time, I quite honestly just forgot all about it because I'm not rolling my windows up and down quite often. But, I came across the problem again today and was wondering if there was a solution for the issue I've been having.
Old Jan 29, 2017 | 06:33 PM
JDM96specCTR's Avatar
try holding it down all the way, and 2 seconds after it gets down. then up all theway and hold for 2 sec after. do it from the driver switch
Old Jan 30, 2017 | 01:20 PM
https://acurazine.com/forums/3g-tl-p...orking-758028/
Old Jan 30, 2017 | 10:00 PM
yup, post number 7... its a little confusing at first but I actually had to do this last night and it worked. took 2 or 3 tries, make sure you follow it exactly how it says
