>>>>Replacing rear sub<<<<
Old Mar 8, 2004 | 05:31 PM
lovepo9e's Avatar
Does any no of any past thread's that give instructions on how to remove the rear deck where the sub is located? Any info will help
Thanks,
hopeless in Sac
Old Mar 8, 2004 | 05:35 PM
Skeedatl's Avatar
Lurker
Try this PDF https://hond**********.hostasaurus.c...unkspoiler.pdf
It's the factory deck lid spoiler instructions, but it shows where the fasteners are for the package tray near the sub.
adam209's Avatar
check in the audio and electronics forum
Old Mar 8, 2004 | 05:52 PM
rkilian's Avatar
Check out the instructions to install the sport suspension, the instructions for the rear decklid are though the trunk, can't touch the sub from the trunk.
Old Mar 8, 2004 | 05:53 PM
Lore's Avatar
CEO, Team Anthracite
You need to remove the seat back and the backseat bench first. That will give you access to the rear deck, which is snapped on using pins. Then you need to take off the two C-Pillar trims which will allow you to pull out the rear deck and access the sub.
Old Mar 8, 2004 | 07:15 PM
lovepo9e's Avatar
thanks guys for all your info. Is there only clips when removing the seat?
Old Mar 9, 2004 | 07:24 PM
phil's Avatar
Question trunk spring installer tool
tl bl/bl/navi bought wing spoiler over ebay do i need tool to do install? any alternatives? if not, we need to pass one around. learning a lot from everyone. keeping 95 accord 2drw/spoiler for 16 year old 150000 bought new. tl came in today in st. louis picking up sat. got the oem 18" wheels also over ebay
Old Mar 9, 2004 | 09:03 PM
Lore's Avatar
Nope. You have to undo 5 or 6 bolts around the seats and release two clips (for the seat bench). Then you have to use a trim removal tool for the C-pillar trims.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
niray9
Dec 8, 2015 07:34 PM
wilztlxs
Dec 1, 2015 09:16 AM
nishant11
Sep 2, 2015 10:34 AM
