Replacing OEM D2S bulbs
Old Mar 28, 2010 | 11:13 AM
Jays07TLtypeS's Avatar
Hello all-
Has anyone ever replaced their factory D2S bulbs with another manufacturer's? I know Acura uses Stanley bulbs as OEM but I have an '07 TL and wondered if replacing mine with a Philips D2S bulb would provide any upgrade (considering Philips is one of the better bulb makers). Also like halogen's, do HID bulbs ever lose any degree of brightness over time/as they age?
Thanks guys!
Jason
07 TL Type-S w/Nav
Alabaster Silver Metallic
Ebony/Silver leather interior
Old Mar 28, 2010 | 11:29 AM
1fsthatch's Avatar
i think you might have to remove the bumper and myabe even headlights (dont take my word for it)...to get to the bulbs.
Old Mar 28, 2010 | 04:54 PM
01tl4tl's Avatar
yes HID bulbs change color and lose brightness with age,
near the end they usually turn pink or purple on initial startup- then failure comes.
Kaixen is a popular brand with gen2- where many ziners have a lot of hours on 10 year old lights and needed new~
4300k is stock color, many prefer 5000k with more blue and still good white, 6000k too blue but liked by many, and above 6 is not worth trying to see at night with!
ck the sponsored sales threads for a few vendors here
Old Mar 28, 2010 | 06:48 PM
kettlepress's Avatar
I just swiched to the Philips 85...+..whatever bulb on my 04TL and they are crazy bright. I would say easily a third brighter than stock. I got them at http://store.theretrofitsource.com/index.php And I had a local VW specialty shop do the install. They gave me an intial quote of $30 to $60, I told them I hear that it's quite extensive, etc and they are prob quoting me to little. No joke, 2 hours later the guy comes out to the waiting room sweating like a whore in church telling me it's done. They were super cool about the whole thing and just told me to pay $65 and swore that he'd never do another Acura headlight job again.
Old Mar 28, 2010 | 08:24 PM
Timb227's Avatar
Fear and Loathing in my
Changing the bulbs are a pain, becasue you have to take the bumper off, and then remove each headlight in order to change the bulb. It's easy if you have taken the bumper and headlights off before but still takes some time.
Old Mar 28, 2010 | 08:41 PM
RjG2's Avatar
Not to jack your thread but does anyone know if the oem hid ballast can handle a brighter bulb? Or do you have change everything if you want to go brighter?
Old Mar 28, 2010 | 10:28 PM
spcslyusarmy's Avatar
Slythslyr
^^^^as long as the bulb wattage is the same you should be fine...
Old Mar 28, 2010 | 11:30 PM
eduardmc's Avatar
Acura TL 04, G37s 19"
I WAS ABLE TO REPLACE THE BULBS WITHOUT REMOVING THE BUMPER OR INNER FENDER. READ MY TREAD IT WILL GIVE YOU AN IDEA HOW TO DO IT. THE ONLY THING I HAD TO REMOVE WAS THE BATTERY , VERY EASY CHANGE.
https://acurazine.com/forums/3g-tl-problems-fixes-114/i-changed-my-ds2-bulb-without-removing-bumper-side-fender-769286/
Old Mar 24, 2015 | 12:57 PM
Brooks Hoy's Avatar
2006 Acura TL AT
06 bulb replacement
ANybody have a step by step for replacing headlight bulb for 2006 acura TL. ive only found 2004-2005 threads. Also, leave bumper on? or take it off?
Old Mar 24, 2015 | 01:05 PM
dezymond's Avatar
I ended up taking my bumper off and even had to take out the housing a bit to get my hand to be able to maneuver to put in the new bulb. It's not easy, but it's not difficult either, just time consuming.
Old Mar 24, 2015 | 01:54 PM
Brooks Hoy's Avatar
2006 Acura TL AT
your link is gone, do you have another one?
Old Mar 24, 2015 | 02:19 PM
Brooks Hoy's Avatar
2006 Acura TL AT
when you say housing, do you mean the entire headlight assembly?
Old Mar 24, 2015 | 02:28 PM
dezymond's Avatar
yes. sorry headlight assembly is more accurate.
Old Mar 24, 2015 | 02:31 PM
Brooks Hoy's Avatar
2006 Acura TL AT
for both driver and passenger? or just driver? also, would removing the battery give the same effect as removing the headlight assembly? as far as extra space
Old Mar 24, 2015 | 03:25 PM
polobunny's Avatar
Registered Bunny
https://acurazine.com/forums/third-g...4/#post8285704
Still valid, really. First link or second link, depending if you want to do it the Acura way or the crafty way by the wheel well. Topic has been beaten to death already.
Old Mar 24, 2015 | 03:27 PM
dezymond's Avatar
If I recall, I removed most of the headlight assembly but wasn't able to fully take it out due to the intake system. I just moved it enough to make access to the light bulb easier. Can be a bit of a pain to do, but it's easy enough.
I don't recall removing the battery making it any easier to access, for me at least. That's why I went through the trouble of taking the bumper off and then unscrewing the headlight assembly enough to move it.
Old Mar 25, 2015 | 09:13 AM
vietxquangstah's Avatar
I tried to do the passenger side and drivers side through the wheel well and it wasn't working out for me. I got frustrated and just ended up removing my bumper and taking the headlights out.
I spent so long trying to do both drivers and passenger side through that wheel well that now I have condensation in my headlights. I was able to remove the bulb (it was hard) but couldn't put the new bulb back in and clip in place.
I probably spent a good 30 minutes on both sides and gave up and took the bumper off
Old Mar 25, 2015 | 11:17 AM
RedStar101's Avatar
3rd Gear
It's simple to remove the bumper, I wouldn't even try thru the wheel well.
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
brjones9
Sep 3, 2015 07:30 PM
voigt
Sep 2, 2015 10:44 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
