Replacement License holder inserts on front bumper?
I just picked up my new TL.
In CA the front license plate is require but isn't regularly enforced. I am thinking about leaving the front license plate and holder off my front so you can see the Acura and it looks nicer.
However when I remove the holder I see that there are 2 little inserts missing where the screws from the holder frame go into the bumper. I don't know if the inserts would snap in or if they were "attached" and could not be reinserted.
Anywhere know where I could find a replacement part for this? It would obviously have to be painted to match.
Originally Posted by lembowski
Check the dealership. They take them out when installing the holder. Maybe you can have them on the look out for your specific color. Also good luck on the fix-it ticket issue. So keep the ones with screw hole so when you have to show up for the fix-it
brianp, assuming your dealership mounted the front license plate holder correctly, there are plugs that will cover the holes on the bumper. I also found my plugs in my glove box. Others just went back to the dealership and asked for them or bought the plugs for a few dollars.
Search the forum for "front plugs" if you want more details.
Please continue this discussion in the big Screw Hole Covers for front plate thread. This thread is now closed.
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
robowarrio
Sep 1, 2015 09:25 PM
