Replacement Fog Light
I have a fog light that took a rock through the lens and needs to be replaced. Where can I get a good deal on an OEM or is there a better alternative that is brighter?
AZ Community Team
Received 7,771 Likes
Sounds like you need the lens not just the light?
The lenses are pretty pricey and nothing to do with "brightness".
What you need and what's available depends on what year your car is. '04 - '06 are not the same as '07/'08.
MuskyHunter,
Acurapartswareshouse.com sells replacement OEM fog light assemblies for $209.89. That's about 80 bucks cheaper than the dealership price for the same part![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
As for the actual replacement procedure, I think that you have to remove the right and left side engine compartment cover and the front bulkhead cover but I'm not sure if you have to remove the front bumper for the foglights. This seems to be the case for replacing the headlight assemblies.
To remove the engine compartment covers:
1. Remove the washer reservoir cap, and release the hooks and pins, then remove the right side engine compartment cover.
![](http://content.chiltonsonline.com/content/images/22140/images/22140_acur_g0018.gif)
**Shown here: Removal of the washer reservoir cap (A), and release the hooks (B) and pins (C), then remove the right side engine compartment cover (D)—TL Models
2. Remove the left side engine compartment cover by releasing the hooks and pins.
3. Detach the clips, then remove the front bulkhead cover.
![](http://content.chiltonsonline.com/content/images/22140/images/22140_acur_g0019.gif)
Hopefully someone else will stipulate whether or not you have to remove the front bumper to replace the foglights
Registered 3.5L Member
I'd hit up your nearest scrap yard and try to get a deal on a used lens assembly
Got my passenger side Fog/Driving Lamp assembly shipped for $141.88 from Rock Auto back in April of this year for my 08 TL Type S.
Part number is AC2593108
Did NOT remove bumper. Went in through the wheel well
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
