Replacement Brembo Calipers
Anyone have experience buying reman. PowerStop Brembo calipers? I was taking a look at RockAuto and these seem to be quite cheaper vs the Centric reman and a bit cheaper than the NuGeon reman. The reason I'm looking for replacement is because the paint on mine is getting super tired and I just plan on respraying/installing the new calipers and selling the old ones. Let me know what you guys think!
LINK: https://www.rockauto.com/en/moreinfo...284&cc=1438264
I assume the red ones you're referencing are the PowerStop ones? I mean end of the day its just reman brembo for all of them, so that shouldn't matter, right?
Correct, given the Brembo calipers used on the 3G 6MT and 3G Type-S models are the exact same caliper used in other cars such as the Mitsubishi Evo, there are plenty of aftermarket units available for remanufacturing.
Don’t do the mistake I did. I said the same oh instead of painting my brembos for the 4th time let me get a rebuilt set that will last many years and I can paint fresh. Nope. They do not feel the same as the oem!! It’s all about the piston inside that makes the difference. I hate the feel of the remans brakes and had to buy a used brembo oem set that I am now refinishing and rebuilding myself. I’ve bled remans many many times and they still don’t feel good. I’ve talked to others and they say the same about their remans.
don’t sell your oem!
I did the same researched a lot before doing it. But I’ve been sorely disappointed and I’ve since talked to a few people that did the same. Don’t know if quality went down or what. Just trying to pass on a warning for others maybe they will have better luck
Who told you that? that guy is a biggest noob tho.
Yes, the only reman I would buy is from Centric. I just was being smart ass with Sockr1 because I am the one who told him about the differences between reman and rebuilt, he then goes well no wonder why the brake pedal never felt the same. If you buy the reman make sure replace the piston and seals with OEM/ Brembo one.
Piston wise I would only buy from Centric, the seal are available through OEM part website. The tricky part is that small o-ring that connect between the two half is hard to find, I believe the Centric rebuilt kit has the small oring as well.
Like SockR1 said new Brembo piston only available through new caliper, if your car doesn't spend time in winter state the piston does not need to be replaced.
Interesting, my car of course does live in a winter/salt state, so I'm assuming sooner or later I'll need to update my calipers. I checked the Brembo site, and while it contains a pretty fair amount of rhetoric saying, stuff like official Brembo products are the best, however, there is no way to buy new or remanufactured calipers for our cars from them. I guess that leaves Acura as the sole source of OEM calipers.
or you can contact Brembo for specific part number.
