Replaced 3rd/4th gear
Quiet, Rika Neenja!
pressure switches, oops, sorry hit enter too early. anyway I didn't have a lappy nearby (was at a buddy's house) and got new switches and wasn't sure which was which. I replaced the brown one with the new brown one (28610-RAY-003 I believe) and the white one with the new white one. are they color coded? How would I know if I had them back asswards?
Thanks!!
Thanks!!
US Navy Seabees
so how is the shifting now that you've replaced them? How long did it take you?
I replaced them 2 weeks ago. Not much of a difference (if any).
Very easy to do, it's easier if you have a 22mm wrench but a crescent wrench will do. Took me less than 30 mins.
@50k miles
@50k miles
Quiet, Rika Neenja!
It's really quick and easy. I was changing my ATF today so I got the switches to do at the same time. turned the wheel all the way to the left, you can see them pretty easily, 4th gear is super easy to get at, 3rd you have to unbolt a couple bolts to get at but you'll see it right away. 22mm socket/wrench makes it easier but I was able to do it with minimal effort with a medium crescent wrench. it's easier to get at with the wheel removed but I had no problem doing it while jacked up with the wheel turned. the DIY makes it seem harder than it is, a video would be best. in retrospect I guess I could have made one with the phone but hindsight is 20/20. if someone in Tampa needs help doing this I'll make a quick video Only bitch is the switches look identical with the exception of the housing color, I'm hoping I put the right ones in the right places. It would be pretty aggravating & ironic if the factory ones were brown and white and then the replacements were reversed lol.
Quiet, Rika Neenja!
oh and regarding shifting i'll have to tell you tomorrow, today I did:
AMSOil Oil & filter
Drained the radiator & block and replaced my HCV valve (which was a whore to get at)
Power steering fluid drain & refill
ATF drain/refill and 3rd/4th sensors
K&N Clean & Re-oil
and I was going to bleed out the old brake fluid, but I had to get to a Christmas party so I bailed, it's still on jackstands.
AMSOil Oil & filter
K&N Clean & Re-oil
2005 AM at/navi
OP, where did you get them from, i dont want to go to my local dealer because i detest those guys.i have been trying to find them on acuraoemparts.com and no luck am i not looking right or where are these found? and can these be found anywhere else than oem parts? thanks.
I got mine at "acuraoemparts.com" Delray Acrua for about 33 bucks each. best price I could find.
2005 AM at/navi
do you remember the part numbers or something? i cant find them? and just a thought why are we only replacing 3rd and 4th switches and we are replacing with stock switches so how do we benefit from this and how do i know if the ones on my car now are bad???
just done mine last night and was very easy, i had a mechanic at the nissan dealership i worked at do it. I baught the car 3 months ago with 82k its almost 90k now when he took switch 3 a little bit of trans fluid drops he said thats aweful brown. SO i said go ahead and do a flush, come to find out its never been flushed its whole life and its darker than old oil wtf. so he changed a few quarts and i will keep doing this every week until its clean but i dont know if its the switches or the fluid but it shifts better to me. great quick diy.
1x - 28610RAY003
2x - 90471PW7A00
I got them for $75 shipped at MagAuto.
http://www.magauto.com/
It's more of a preventative maintenance thing. It's recommended to change them every 50-60k miles.
Quiet, Rika Neenja!
https://acurazine.com/forums/ramblings-12/anybody-good-xp-89064/
It's just my humble opinion, but I really think everyone should at the bare minimum print out a list of the topics in the sticky garage thread, and before changing any component of the car or any fluid or anything like that, read what the pros recommend. Shops that aren't acura/honda specific may not recommend the right thing for your car. I had a car about 8 years ago where the tranny shit itself (literally exploded all over the road) about 2000 miles after I had a flush and fluid change. I chalked it up to bad luck, until I started educating myself on these boards and while reading that thread above I had one of those "...son of a BITCH" realization moments
US Navy Seabees
Rut-ro scooby, you aren't supposed to flush our transmissions, you're only supposed to change the fluid three times, with a 5 minute drive in between each change. flushing can seriously damage the transmission.
https://acurazine.com/forums/showthread.php?t=89064
cycdaniel
12-17-2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Mike Bertram
09-10-2015 09:27 AM
