Removing Rear Wing Spoiler
Old 02-12-2007, 06:13 PM
4th Gear
TL in SC's Avatar
My 2005tl has a rear wing spoiler. I am leaning toward removing it. Without all the comments about likes and dislikes, is there a simple way to do this or I am stuck with repairing holes in the existing trunk or replacing the trunk altogether? Suggestions/thoughts appreciated.
Old 02-12-2007, 06:35 PM
GO DAWGS!! SICK'EM!!
TL1999's Avatar
did you had the drilled or used tapes to put this wing spoiler on?
If you use drill, it will be wise to replace the whole trunk if you remove the wing.
And it will be the same if you tried to patch the holes where you probably need to repaint too.
If I were you, I will leave the wing spoiler alone since I don't want to spend the $$ to repaint/replace the truck.
Old 02-12-2007, 06:42 PM
4th Gear
TL in SC's Avatar
I assume it is drilled since it is the wing spoiler. I thought only the lip used adhesive. I have never looked at it that closely.
Old 02-12-2007, 06:47 PM
ttribe's Avatar
Received 5,902 Likes on 2,907 Posts
I also had the wing spoiler installed and I am pretty sure it is drilled. Sounds like your best bet if you really wanted to get rid of it, would be to replace the entire decklid. Not a fun (or inexpensive) proposition.
Old 02-12-2007, 09:04 PM
Starcraft II addict
Buda's Avatar
It is bolted on. 3 holes on each side if I remember right. I looked at mine when I took the liner off to install the backup camera and Cold Cathodes.
Old 02-13-2007, 12:59 PM
FriscoNick's Avatar
I am having second thoughts on my wing spoiler. I was thinking of having the dealer remove it.
Old 02-13-2007, 01:59 PM
ATJ32's Avatar
Why dont you ask to see a member here with the same color if they want it, and just meet up and swap the whole trunk. Its a five hundred dollar accessory, should go to a meet and I am sure somebody will be happy to trade. Cant be too hard to do, that way both of you can benefit from the whole deal. Just my , good luck and the spoiler dont look too bad.
Old 02-13-2007, 03:49 PM
FriscoNick's Avatar
That is a great idea!!!
Old 02-13-2007, 06:42 PM
4th Gear
TL in SC's Avatar
I agree...that is an excellent idea! Thanks.
Old 03-03-2007, 11:51 AM
backthatACup's Avatar
about lip spoilers(somewhat offtopic)
im looking to trade witha friend, hes got a lip spoiler and im certain it uses a heavy duty adhesive. how hard is it to take off and the best way to since its not my car as i dont wanna ruin or pot. damage his ride, if someone can pm me asap or let me know very soon thatd be awesome, thx ziners..
Old 02-08-2011, 08:34 PM
88hybrid's Avatar
I've been trying to do that for months now and im having no luck.
Old 02-08-2011, 11:04 PM
AM To WDP In My Garage
acura_dipset_tl's Avatar
This thread is almost 4 years old.
Try putting a Wanted to Trade thread in the Black market. You might have some luck there.
o8 ENVII 8o
11-30-2015 04:23 PM
oyayjoe
09-12-2015 04:40 PM
EE4Life
09-11-2015 10:13 PM
Ratheruneeq
09-05-2015 06:46 PM
09-04-2015 08:03 AM
Quick Reply: Removing Rear Wing Spoiler
