Removing Rear Wing Spoiler
My 2005tl has a rear wing spoiler. I am leaning toward removing it. Without all the comments about likes and dislikes, is there a simple way to do this or I am stuck with repairing holes in the existing trunk or replacing the trunk altogether? Suggestions/thoughts appreciated.
GO DAWGS!! SICK'EM!!
did you had the drilled or used tapes to put this wing spoiler on?
If you use drill, it will be wise to replace the whole trunk if you remove the wing.
And it will be the same if you tried to patch the holes where you probably need to repaint too.
If I were you, I will leave the wing spoiler alone since I don't want to spend the $$ to repaint/replace the truck.
Originally Posted by TL in SC
I assume it is drilled since it is the wing spoiler. I thought only the lip used adhesive. I have never looked at it that closely.
Originally Posted by ttribe
I also had the wing spoiler installed and I am pretty sure it is drilled. Sounds like your best bet if you really wanted to get rid of it, would be to replace the entire decklid. Not a fun (or inexpensive) proposition.
Originally Posted by FriscoNick
I am having second thoughts on my wing spoiler. I was thinking of having the dealer remove it.
Originally Posted by ATJ32
Why dont you ask to see a member here with the same color if they want it, and just meet up and swap the whole trunk. Its a five hundred dollar accessory, should go to a meet and I am sure somebody will be happy to trade. Cant be too hard to do, that way both of you can benefit from the whole deal. Just my , good luck and the spoiler dont look too bad.
about lip spoilers(somewhat offtopic)
im looking to trade witha friend, hes got a lip spoiler and im certain it uses a heavy duty adhesive. how hard is it to take off and the best way to since its not my car as i dont wanna ruin or pot. damage his ride, if someone can pm me asap or let me know very soon thatd be awesome, thx ziners..
oyayjoe
09-12-2015 04:40 PM
09-04-2015 08:03 AM
