Remount Aspec lip
Remount Aspec lip
Anyone ever had to remount their aspec Lip kit? I'm looking to remount mine cuz of a little gap on the corner. However where can I get a replacement mounting tape kit? I do have automotive 3G tape which is what I used but I found out that it's too thick and causes like a 1mm gap so I need the oem mounting tape kit for a proper flush mount. Btw, that own mounting tape was really strong! Took awhile to remove
I had bought this lip and bumper used so the prev owner put some kind of adhesive at the gap but it didn't hold so through the gap I can see the leftover adhesive which bothers me a bit. You guys dont have that right? In trying to confirm if it was from te prev owner or the lip comes with that adhesive
I bought a used front lip also and will probably need some double stick tape. I'm also looking for the brackets, if not I'll have to use some shit from a hardware store. OP, hope you figure it out and then post what you did.
SSM FTW
i had to remove my lip to install my fogs. been researching 3m tape, some people dont realize that there are hundreds of 3m products LOL. i narrowed it down to this:
http://www.amazon.com/3MTM-VHBTM-Hea...ef=pd_sbs_op_1
a friend of mine had that and let me tell you.... that stuff is really heavy duty industrial strength stuff. it sells for about $40 per roll at home depot or other hardware stores. that stuff you linked is the real deal. it doesn't get any better.
and if it does, i don't know about it
my rear a-spec lip is a little sagging. i need to re do it, but i don't have any double sided tape to do it. i was thinking about buying what you linked, but $40 is pretty steep, especially considering that i only need about $5 or $10 worth of tape lol.
if i had a job i'd buy it and re do my lip.... but money is tight so little things will have to wait!
calrow
05-03-2017 10:21 PM
