Relocating the front plate
Old Jul 19, 2010 | 01:52 AM
chinkwapin's Avatar
.:dedicated:.
okay, i've been asked this question countless times (how do you mount your plate like that???), so i decided to finally make a thread to direct people to rather than repeating myself over and over.
if you want to mount your plate like this you should
1) call your local autozone and ask if they have this: http://www.autozone.com/autozone/acc...er=761575_0_0_
2) go pick it up (you'll only spend about $10!)
3) unpack it and test fit it before drilling
4) i forgot what size drillbit to use, but start out small and work your way up. drill upwards into the bumper in the desired location (mine is mounted in the middle of the driver side lower grille) i made sure there was nothing behind the bumper to accidentally damage, so this is the ideal location to drill
5) use either the pointy threaded screws or the nut/bolt combo (both included in the set) and mount the bracket
6) adjust the angle of the bracket to your desired angle
7) mount the plate using included hardware (i left out the tacky chrome covers that go over the bolts in the front cuz they look kinda lame but u can use them if you want to...
8) enjoy driving around without the eyesore of the OEM plate holder AND don't worry about fix it tickets!
if you show your car or take pics of it and dont like the plate on, you can simply remove the plate and bracket and since you drilled upwards into your bumper, there are NO UGLY HOLES! woot!
Old Jul 19, 2010 | 07:31 AM
LoveMyTL-S's Avatar
Thanks for the info!
Old Jul 19, 2010 | 09:34 AM
sixsixfour's Avatar
looks good. im just not a fan of blocking one side of the lower bumper openings.
Old Jul 19, 2010 | 11:05 AM
huystAr's Avatar
^ +1
Old Jul 19, 2010 | 11:57 AM
images's Avatar
05 NBP
then attach the thing to the bottom of your plate instead of the top
Old Jul 19, 2010 | 12:14 PM
chinkwapin's Avatar
.:dedicated:.
I'm just describing the way I did it but the bracket is universal and adjustable and can be attatched virtually anywhere on the bumper
Old Jul 19, 2010 | 12:17 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Nice write-up!
Old Jul 19, 2010 | 03:58 PM
ionojimbo's Avatar
is this thing durable or flimsy?
Old Jul 19, 2010 | 04:03 PM
AMUA6's Avatar
ScoobyZINE
I almost wish TN required you to have a front tag..
Old Jul 19, 2010 | 06:28 PM
chinkwapin's Avatar
.:dedicated:.
i have had it for about 6 months and im very pleased with it. currently the bottom of my plate sits very close to my aspec lip (like less than 1 inch) and the bracket doesnt even allow the plate to hit the lip at highway speeds. you can see how close it is in the pic i posted above. there are no visible marks of any contact between the plate and the lip. it is made out of some sort of metal, so its not plastic. the only thing is that the bolts that hold the license plate up are getting a little rusty, but its not terrible and not something i'm worried about
you should just pick one of these up to be different. i actually think it could be considered an aesthetic mod
Old Jul 20, 2010 | 03:46 AM
huystAr's Avatar
im probably gunna be doin this mod soon thanks to this post so thank you chinkwapin but had a couple concerns/questions.
not really sure but, driver side = air intake? and left side = ? like sixsixfour said about blocking the openings, i wouldn't wanna do that so would it be better if it was placed on the passenger side? just looking for the best location..
Old Jul 20, 2010 | 02:12 PM
chinkwapin's Avatar
.:dedicated:.
location is purely up to you. honestly I don't buy that blocking the intake hole stuff but that's just me. I think the difference is negligible. either side should be fine and it's just up to you
Old Jul 20, 2010 | 02:46 PM
images's Avatar
05 NBP
you can just bolt the mount to the bottom two holes of the plate instead of the top two if you're worried about blocking the intake hole, similar to how bforbrian mounts his
i'm pretty sure he's had it on the drivers side higher up, but he changes shit so often i could be wrong.
Old Jul 20, 2010 | 03:55 PM
ionojimbo's Avatar
i see well i guess for those of us that worry can just put a thin rubber lining on it also
Old Jul 20, 2010 | 04:17 PM
chinkwapin's Avatar
.:dedicated:.
it looks like in this pic he's using a tow hook mount, not sure tho
Old Jul 20, 2010 | 05:21 PM
images's Avatar
05 NBP
i was just giving a ballpark reference for location, i know that in that picture he isn't mounting it the same way
Old Jul 20, 2010 | 05:36 PM
sixsixfour's Avatar
i think so too. looks the same as mine.
Old Jul 20, 2010 | 06:28 PM
huystAr's Avatar
ill probably be doing mine on the passenger side then, thanks.
oh and im pretty sure he's using a RHO Plate.
Old Jul 20, 2010 | 06:38 PM
images's Avatar
05 NBP
read.
Old Jul 20, 2010 | 08:08 PM
syracusewhitey's Avatar
I picked up black round Velcro tabs w/sticky on one side and put 2 on the back of my plate and 2 on my bumper 90% of the time I run w/no front plate but when I'm misbehaving I stick it on just to satisfy the man.
Old Jul 20, 2010 | 09:22 PM
chinkwapin's Avatar
.:dedicated:.
but when you're not running the plate cant you see the velcro tabs? and if you decide to remove them later, they may be a sticky residue left on your bumper.. not my cup of tea but i guess it works!
Old Jul 20, 2010 | 11:11 PM
AMUA6's Avatar
ScoobyZINE
What would I put on it?? An old school vanity tag? lol
Old Jul 25, 2010 | 03:14 AM
chinkwapin's Avatar
.:dedicated:.
sooo has anyone done this yet? i'm interested to see different setups with this bracket because there are so many ways you can go with this part
Old Aug 30, 2010 | 11:16 AM
images's Avatar
05 NBP
Just did this 2 weeks ago, thanks for posting this.
I was actually considering dropping 60 dollars on a RHO-plate.
This thing cost me 9$ at autozone, and is much more versatile and in my opinion, looks much better.
Old Aug 30, 2010 | 11:23 AM
VQPower37's Avatar
looks nice ... when and if i have to put my va plates back on then i am def gunna do this mod. but now with my mi plates, NO FRONT PLATE!!!
Old Aug 30, 2010 | 04:05 PM
AMUA6's Avatar
ScoobyZINE
I wanna do it to add to the aesthetics, but not sure what kind of plate to put on the front since TN doesn't require a front plate?
Old Aug 30, 2010 | 04:26 PM
images's Avatar
05 NBP
if you dont need one dont add one =(
just look up some funny vanity plates there should be tons
Old Aug 30, 2010 | 04:33 PM
AMUA6's Avatar
ScoobyZINE
I'm gonna call the courthouse tomorrow to see if I can get a duplicate plate of the one I have now, to go on the front
Old Aug 30, 2010 | 07:09 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
A few zip ties, duck tape, and rocket science.
Obviously no plate is best, but if you have to....
Old Aug 30, 2010 | 11:35 PM
AMUA6's Avatar
ScoobyZINE
^^ Did you take it to the moon?
Old Aug 31, 2010 | 12:38 PM
nate2fresh's Avatar
thanks, whats the name of your rims there really nice??
Old Aug 31, 2010 | 01:06 PM
chinkwapin's Avatar
.:dedicated:.
me? they are Volk LE37
Old Sep 4, 2010 | 10:35 PM
JonBeast's Avatar
Just call me JB
If you don't have to run a front plate...why the hell would you?
Front plates FTL...but if you have to, mount it like the OP
Old Sep 5, 2010 | 12:16 AM
AMUA6's Avatar
ScoobyZINE
^^^ Cuz I'm weird lol I like the looks of it.. I forgot all about this and since Monday is a holiday, I won't remember again until this thread gets bumped lol
Old Feb 18, 2011 | 05:17 PM
tehloxely's Avatar
I was considering the RHO Plate a while ago. This new method from AutoZone seems nice, but I'd rather not drill into anything...
Old Feb 18, 2011 | 06:54 PM
stvtec's Avatar
'06 WDP TL 6MT
How did I miss this thread? I did the same thing myself for about $9 using Lowes parts!
Old Oct 10, 2011 | 08:52 PM
canitolindo's Avatar
This thread is old but helpful thanks for the reviews on this kit cause I just bought one and was curious tohow good it was gonna look and fit.
Old Feb 4, 2012 | 04:29 PM
goodoldayz's Avatar
any one use the ones like these ? either that or an extra RHo plate for cheap ?
http://www.ebay.com/itm/120851081694...ht_3792wt_1348
Old Feb 4, 2012 | 05:45 PM
Jesstzn's Avatar
No image ..
Old Feb 5, 2012 | 04:30 AM
goodoldayz's Avatar
Originally Posted by Jesstzn
No image ..
fixed
http://www.ebay.com/itm/Jdm-Universa...#ht_500wt_1156
