Recommend the quietest front pads for an 04 TL A/T
Old 06-08-2009 | 06:37 PM
LiquidLunch's Avatar
My front pads squeak so bad it is making me nuts. I spend alot of time in stop and go traffic and I need the quietest pads available. The rotors are in good shape- no groves. I am going to have them cut just to ensure there is no rotor warping. I will replace all hardware and shims.
I don't care about brake dust. I can clean my wheels. I just want quiet brakes. What do you recommend?
Old 06-08-2009 | 07:48 PM
sunny201's Avatar
A J35A8 EG civic is in
I have the Duragold? CMAX Gold pads. I forget what the company name is, but Autozone sells them for about $70.
Old 06-08-2009 | 07:51 PM
Any squeaking problems? Thats my biggest concern. I want the quietest pads available. I assume those are ceramic pads?
Old 06-08-2009 | 08:45 PM
flyromeo3's Avatar
what about oem?
Old 06-08-2009 | 08:51 PM
woot427's Avatar
Lunch -- are you using the OEM pads right now? I am in a lot of stop and go trafic as well, and dont experience much squeaking.
I wonder how the a-spec brake pads perform as far as quietness goes.
TheChamp531's Avatar
Chapter Leader (San Antonio)
OEM is OEM in the middle. Duralast CMAX Gold Pads are good, quiet, and worth the money. Lifetime warranty also
Old 06-08-2009 | 08:54 PM
sunny201's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/duralast-brake-pads-question-710809/ Theres the thread on the Duralast CMAX Gold pads. and yea, theyre ceramic.
Old 06-08-2009 | 09:54 PM
csmeance's Avatar
Acura A-Spec Scotched pads, they dust a bit more over stock, but mine don't squeek and as well they stop on a dime.
Old 06-08-2009 | 10:00 PM
woot427's Avatar
do they need to be on front and rear or just on fronts? Pardon my ignorance.
Is this a good deal? http://cgi.ebay.com/ebaymotors/04-08-OEM-ACURA-TL-A-SPEC-BRAKE-PAD-UPGRADE-SET-FF-RR_W0QQitemZ260419590788QQcmdZViewItemQQptZMotors_ Car_Truck_Parts_Accessories?hash=item3ca2379a84&_t rksid=p3911.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1 |72%3A317|240%3A1318
You would need to buy both available in this auction to complete the car, correct?
Old 06-08-2009 | 10:09 PM
csmeance's Avatar
I bought all 4 for about 110 dollars plus shipping from some dealership...
Acura of Peroria has it for 104 plus shipping
part # 08P89-SEP-200
http://oemacuraparts.com/partlocator...&siteid=214055
and
Delray Acura has it for 104 as well
http://www.acuraoemparts.com/delray/...1=&inputstate=
call em up and see which can do cheaper shipped...
BTW these are heavy, about 15lbs...
Old 06-08-2009 | 10:17 PM
woot427's Avatar
so the $104 gets me all four? (part #: 08P89-SEP-200)
Old 06-08-2009 | 10:49 PM
csmeance's Avatar
yup, and they include the shims and the grease + instructions on how to install them...
Old 06-08-2009 | 11:05 PM
woot427's Avatar
lol, im the least bit DIYer unfortunately. thanks for all the info
LiquidLunch -- maybe you should try out the a-spec pads!
And you say they are a little heavier but better performance? I'll be getting a-spec wheels soon. How is the performance of OEm pads with a-spec wheels. are the aspecs heavier than the OEM 5 stars? maybe i should i go to the a-spec pads at the same time put the wheels on
Old 06-09-2009 | 12:12 AM
csmeance's Avatar
they weight the same as regular brakes, but the shims included make the package about 15lbs verus just getting the pads.
Old 06-09-2009 | 12:32 AM
woot427's Avatar
ah ok thanks, and whats your opinion/suggestion on maybe putting them on same time i get the aspec wheels?
Even though these listed are for 07, they shouldnt have any problem working, right? They're cheaper than a full set of OEM non aspec pads...is that right?
Old 06-10-2009 | 08:49 AM
Majofo's Avatar
I have the Duralast Gold Ceramics on for 10k miles on my TL and 6k miles on my MDX now and very little dusting (the car gets dirty before the wheels) & NO NOISE.. Not a squeak / squeal / shimmy.. solid pads to say the least & there is a lifetime warranty on them so when they're toast.. take'em back and pick up a new pair free.
Old 06-10-2009 | 08:41 PM
Well.. it was a toss up between OEM pads and the Duralast Duragold CMAX pads. Turns out I can get a better price on the OEM pads than the Duralasts so I am going to go OEM. But before that I have a custom trim shop replacing all the perforated panels on my drivers seat and the side bolster pieces on the seat bottom. I also have a broken wheel stud that will be getting fixed. Then I will do the brakes. I'll post an update as I have them.
Old 06-10-2009 | 10:12 PM
Majofo's Avatar
^ I don't get it.. how is it a better price when the DG Cmax pads are lifetime warrantied? OEM pads are super dusty as well.. your money though..
Old 06-10-2009 | 10:59 PM
NAiL05's Avatar
Ceramic pads usually dont squeak only semi metallic or metallic pads. So you have a wide variety to choose from. Ceramics usually cost more =D.
yesSIR-S
05-13-2016 05:42 PM
08 NBP TL
09-08-2015 08:49 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
09-04-2015 08:03 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: Recommend the quietest front pads for an 04 TL A/T
