Rearview Mirror w/compass for '05 TL non-Navi
Master Tasker
Hey guys - I have '05 TL non-navi and am hoping to put the auto dim rearview mirror with compass in but Acura doesn't offer one. I'm wondering if anyone know whether one from the '05 Accord would work? The part number I come up with is either 08V03-SDA-100B or 08V03-SDA-101A.
Alternatively, does Acura offer one for a different vehicle that would work?
I tried a Gentex model on my '06 Odyssey rather than go with the OEM version and it just didn't work right so I'm hoping to find the actual Honda/Acura product this time. I know that Gentex makes alot of the OEM stuff, but want to stick with OEM branding this time.
Also, I'm going to have to disconnect battery for this install and don't have the radio code as I bought the vehicle used. Anyone know easiest way to find it or get it from Acura?
Any help or suggestions are welcome. Thanks!
Keeping it simple
Would be interested to see how this can be accomplished....
I asked about putting a TPMS in an 05 and couldnt get any answers besides "just get another car" ....... I even searched.....If you come up with something it'll be cool if you share it...I would like to have this in my vehicle...
Master Tasker
Thank TrackRunner, I saw that but don't want the headache. I have the exact Gentex mirror in that post in my Odyssey and it doesn't cut the mustard. . .
I may just have to get an Accord or other Honda mirror and see what I can do. I'll let you know how I make out.
Still open to other suggestions in the meantime. . .
get the accessory one for the 07 MDX from a dealer. The 07 is the only year it is available for.
Master Tasker
Originally Posted by Jawbone
Can't help you with your rearview mirror question but I think In order to get your radio code you have to get the serial number on the back of your radio or navi and call the dealer to have them look it up for you.
csmeance - exactly what I was looking for. I found the instructions at handaaccessories - it's the exact same mount as in my TL. Thanks!
For anyone who's interested, the instructions are HERE and the OEM part number for the '07 MDX day/night mirror w/compass is 08V03-SDA-100B
Keeping it simple
^^^ Awesome thanks for this....I'll try tackling this in the next few months...
At the momet Im trying to get the TPMS to work....If I accomplish this then I'll post it up!!
Jokerman
Thanks Jawbone - I actually found the code on the side of the glovebox - doh!
Master Tasker
Originally Posted by jokerman826
in the istructions the mount looks different, but i could be wrong. Also is the compas built in or does it need a seperate cable to go to something else? I guess i will have to wait for you to see whats up with it, make sure you keep us informed.
New question - anyone know which other Acuras/Hondas also have that same pressure spring mechanism for the rearview mirror?
Team Anthracite
Master Tasker
Originally Posted by rockyfeller
Actually how exactly do you get the rearview mirror off? I was trying to get mine off the other day and couldn't do it. I didn't want to break anything. I searched the forum and no luck. Technique?
You can use the rear view mirror off a nissan with the compass (maxima) and it will work just fine.......Unlike Acura, Nissan has both navi and rear view mirror set up with compass
Master Tasker
Thanks - the mount is not the same. The mount is the big issue. I could use any variety of Honda, Acura, Nissan, Donelly, etc, except that I was hoping to not have to put a new mount on the inside of the windshield.
Master Tasker
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
OK Guys, I FINALLY bit the bullet and did this mod. After months of searching I found no RV mirror with compass that has compatible mount with my '05 TL. Soooo, I opted for a Donnelly temp/compass RV mirror (bought new on ebay for $80) with a standard mount. Removed the OEM mirror as indicated in other posts here - removed map lights and overhead moulding, unplugged mirror harness, tapped gently on mirror bracket in downward motion to remove.
Then I simply attached the new mirror just below the other being careful not to damage the glass. I left the old mounting plate on the glass - you cannot see it as it is above the line of the map light moulding at the roof line. Used wire splices to tap the power from the existing harness, and - yes - I did run and hookup the new temp probe. Even though my TL has the temp gauge already in it, I figured it doesn't make much sense to have the temp on the mirror and not use it.
REMEMBER - if you do this mod be VERY CAREFUL OF YOUR WINDSHIELD!! It will crack easily. That's why all of that black reinforced area is around the existing mirror mount.
I know this is not for everyone but it works for me! If anyone is interested in photos or more detail, let me know.
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
08v03sda100b, acura, compass, cord, daytona, injury, installing, instructions, manual, mdx, mirror, powered, spinal, tl, vbulletin
