Rear plate - protect car?
Team Anthracite Member
I just replaced my 30-day tag with my new license plate. I noticed that the plate fits right onto the clear part of the car. I'm worried that, over time, the plate is going to scratch the clear plastic due to vibrations from driving.
Has anyone placed any type of protector between their rear license plate and the surface of the car?
If so, what did you use?
Team Nighthawk MechE
Good point... I'm getting my new plate within a week, and after hearing this I may stand the plate off a little using some 3M one sided adhesive foam tape... It's only a couple mm's thick but should keep the plate off the car a little bit. (Obvisouly the sticky side to the plate, not the car!)
That should work...
That should work...
professional TL driver
although i understand what you are doing. i kinda dont understand why though the car will always have a plate on it.... unless it falls off. and even then you have to get a new one.... maybe its just me?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
05.TL.WDP.DYN.NAVI
Originally Posted by ONAGER
although i understand what you are doing. i kinda dont understand why though the car will always have a plate on it.... unless it falls off. and even then you have to get a new one.... maybe its just me? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Protection.
I took the thin plastic dealer advertising insert (size of a plate with the dealers name on it), that was put on the car at delivery, and put it behind the license plate to protect the trim panel.
But any sort of foam tape applied to the back of the plate should work equally as well.
Originally Posted by tkx
It's nice to have a car as good condition as you can have it...even if you cannot see it.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
I hadn't even thought of that. Since I've had my car for over a year, I'll have to look at how badly the plastic is scratched. Will check if I ever get home from work tonight (it's been a LONG day...)
Originally Posted by cvajs
some states only require rear plate to be on.
and for the record, i only have a rear plate
The very first post stated (at least he was) talking about the rear plate
kinda same issue with front plate too...
Oakes
Wash & Wax
10-12-2015 11:17 AM
