Rear motor mount
Old Apr 23, 2020 | 01:43 PM
Mike14's Avatar
6th Gear
Rear motor mount
Rear engin Mount does the engine need to be jacked up to replace the rear motor mount see videos and looked liked they did not have to unless just didn't put it in the video ?
Old Apr 23, 2020 | 03:16 PM
t-rd's Avatar
Yes you do. It does not just pry out easily unless you give it a gap.
You also need to offload the suspension by putting the front end on jack stands first. The engine does not lift off the rear mount if the suspension is loaded.
Old Apr 23, 2020 | 06:57 PM
Mike14's Avatar
6th Gear
Thanks got all the bolts loose and will try the Jack stands and lifting the motor tomorrow where is the best Jack placement to support the motor
Old Apr 23, 2020 | 11:14 PM
HVAC34's Avatar
I think it’s doable with the car on the floor if you loosen the passenger side mount so the motor could have play.
Old Apr 24, 2020 | 10:02 AM
t-rd's Avatar
The engine does not lift off the rear mount with front or side mount loosened, sitting on the floor. I already tried this.
You need to jack toward the very rear of the transmission, with a piece of wood block on a hydraulic jack.
Old Apr 24, 2020 | 01:28 PM
HVAC34's Avatar
I’m just saying I did innovative mounts last year..... not once did I “unload” the suspension.
Old Apr 24, 2020 | 05:56 PM
t-rd's Avatar
Perhaps my lowered suspension is the difference.
Good tip
Old Apr 25, 2020 | 07:37 PM
Mike14's Avatar
6th Gear
Thanks for the suggestions and advice rear mount successfully changed out got it done with only a floor Jack 👍🏻
mattcl-s
2G CL Problems & Fixes
Apr 20, 2016 07:02 AM
OnlyDaanish
Nov 16, 2015 10:17 PM
iiamchili
Jan 22, 2015 02:30 PM
2ndgentl
Apr 23, 2008 07:51 PM
mikey3.2
Aug 3, 2006 12:50 PM
