rear Brembos?
Old Mar 7, 2004 | 05:00 PM
Ronin_62's Avatar
rear Brembos?
Is it mechanically possible to change the stock rear brakes to Bremo's like the front brakes? (assuming the dealer would sell you the parts and do the warranty)?
I've read that the TL has longer braking distances than comparative cars (G35, etc.), and thought maybe rear Brembos would help out
Has anyone given this any thought?
Old Mar 7, 2004 | 05:07 PM
Skeedatl's Avatar
Lurker
Rears only contribute to 15% of a cars stopping power. Bigger front brembos and stickier tire would be the solution.
Old Mar 7, 2004 | 05:10 PM
TLover's Avatar
Agreed. And better pads.
Old Mar 7, 2004 | 05:12 PM
adam209's Avatar
Re: rear Brembos?
since the dealer will only carry the fronts, they probably won't be able to help you. take a look at brakes up at the top of the screen because they have brakes for the rear that would help.
Old Mar 7, 2004 | 05:13 PM
Skeedatl's Avatar
Lurker
That's true too. Pads are very important, like the A-Spec kit coming with new non-MT HP pads. Anything to help dissapate the heat helps too. Doing just a little tinwork, fabbing up break ducts in the front vents would make a big difference if you routinely beat your brakes (like have a hilly commute etc).
Old Mar 7, 2004 | 05:19 PM
adam209's Avatar
slotted rotors are good too
Old Mar 7, 2004 | 05:38 PM
caball88's Avatar
don't waste money on the rear brakes, it won't help braking performance that much. just get a set of sticky tires and breaking will improve.
Old Mar 7, 2004 | 06:59 PM
Re: rear Brembos?
Ronin, where have you read this? I don't know about other sources, but in the most recent C&D comparo ($35K Sports Sedans) the TL beat the competition in stopping distance (the TL tested did have the HPT's):
Braking Distance (ft) 70-0 mph
TL - 160
G35 - 164
IS300 - 167
325i - 172
X-type 3.0 - 175
A4 3.0 - 183
9-3 Arc - 185
At least this is a same driver/same day/same surface comparison.
- Peter
Old Mar 7, 2004 | 08:47 PM
Ronin_62's Avatar
hmmm i read the C&D website and you're right , Peter
but I saw this review on TV (I had thought it was C&D) on Speed channel and they said TL had the worst stopping distance, by like 30 or 40 feet difference
maybe they were testing an auto without Brembos?
Lucrativesoldier
Sep 28, 2015 03:47 PM
TL-GIXXER
Sep 18, 2015 10:25 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:10 AM
jmoney2001
Sep 11, 2015 12:07 PM
