Rattle in center console
Old Nov 24, 2004 | 08:42 AM
joeyespo's Avatar
9th Gear
Driving me crazy......3rd day with the car, started only when going over bumpy roads....i pulled into a parking spot at work and put the car in park and still was experiencing this rattle. I tapped on the dash for a little bit and it seemed to make it a bit louder. I shut the car off and turned it back on, it was quiet for a few seconds and then started to rattle again. This has probably been asked a million times before but does the dealer fix this, is it fixable? I am also curious to see if anyone else has this and had it fixed or is living with it. everything else is great though !!!
Old Nov 24, 2004 | 08:53 AM
willz822's Avatar
Can you be a little more specific as to where the rattle may be coming from? Either way, the dealer should be able to fix this problem.
Old Nov 24, 2004 | 08:55 AM
Novice's Avatar
Make sure you check this section-it lists every possible rattle issue and some DIY fixes.
https://acurazine.com/forums/showthread.php?t=84834
mlody
Dec 4, 2019 02:11 PM
vpasla1
Sep 17, 2016 07:24 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
