Racingbrake ET300 and ET500 pads have been added for Brembo on BMO specails
http://www.heeltoeauto.com/Heeltoe-B...-pr-40007.html
Now you can get Racingbrake ET300 or ET500 pads to compliment Racingbrake rotors on your Brembo equipped TL!
Marcus
PERFORMANCE STREET: ET300 - Delivers the braking performance beyond the street driving yet very low dust and no squeaking.
AGGRESSIVE STREET: ET500, ET700, ET800 - These compounds are offered for the adventurous drivers who:
- Do not like loud squeaking
- Do not like a lot of dust
- Do like extended rotor life
Being these pads are streetable therefore they are not intended for intensive and continuous hard braking over the temperature and speed limit (see chart below) on the race track, otherwise excessive wear may occur.
ET Series Characteristics:
* Excellent Modulation
* Consistent friction and torque output
* Run from ambient temperature (even in cold winter morning) - ET300, ET500 &
Recommended Application:
Setup # Application Compound Recommended For Speed (MPH) Top Temp.* Min. Temp.
S1 Street Performance ET300 Street - Not Rated Ambient
S2 Autocrossing / Spirited Driving ET500 Aggressive Street 80 1000°F (538°C) Ambient
* For intermittent service only and it requires cool off between braking. The top temperature indicated is not for continuous hard braking.
Marcus
AZ Community Team
Received 7,770 Likes
Originally Posted by Kennedy
ET 500's are the shit. I'm running them with my Racingbrake 2 piece rotors.
- No noise
- Dusting seems acceptable
Great braking performance so far, I have no complaints at all.
- No noise
x2
Got 'em on the 2G TL-S with RB slotted 1-peice fronts.
I have car ADD
but Marcus can I ask you
quite a few members have had problems make the rotors fit with the mounting screw
granted, that screw is purely optional, and you can run rotors without it.. and even if you use it, chances are when rotor service comes along, you'll need to torch and pry the hell out of the screw.. but i kind of like the idea, knowing the screw is in place... especially since I change my wheels constantly (always taking my 20" wheels off for long drives, or areas with really bad roads)
Is there a way you voice this to Racingbrake, or find out why the screw isnt fitting?
If im not mistaken, Kennedy, didnt you have this problem a week or two ago?
Quite literally the hole is drilled in the wrong place on this car. Actually the fronts usually are fine, its the rears that have the issue on the 3G (I am pretty sure). I think it has to do with cross platform compatibility on the rotor fitment, but different hub on different cars have the wandering screw hole.
If this is the case, Honda is the culprit for moving the hole around. I have no idea if this is right but it is my best guess. I will drop a line to RB to get some more input.
Marcus
AZ Community Team
Then, on the driver side front, I stripped the heads trying to remove them. Had to drill 'em out/bust the heads off. So, despite best intentions, I still end up with out all of the retaining screws.
I've learned to live with the dissapointment (and with out the screws).
OMGWTF4THGENTL
For the rear rotors, the hole is about 3mm offset. Not a big deal at all. I believe this is because these rotors also fit the RL, which is a crossover part, which likely has the hub hole offset 3mm the other direction. I dunno...
The calipers, pads and lugs hold the rotor in place when the wheel is removed. You can't even kick it loose. There is really no need at all for the screws.
Steve Wood (of RB) said they were considering completely removing the screw holes to prevent this in the future.
Don't let this minor issue sway you from running a superior product.
OMGWTF4THGENTL
sweet.. .i may go for them
but... holy mother of god... $580 for front rotors? they must be that good, huh?
Funny you balk at that price but don't flinch at a $2400 BBK. How much of that cost is calipers? 1/2...
Precision machined 2 piece aluminum hat rotors... Yeah.
Kennedy....don't forget, the hats are FORGED. Not just billet.
Marcus
I have car ADD
actually, the BBK i had before (Rotora) was only like $1300 or so.... but that was 13" 1pc rotors.. the 14" 2pc rotor kit was like $1700.. so i guess the price is right
Also, i saw a Wilwood 4pot BBK GB on ... it was only $600... BUT... +550 if you wanted to upgrade to 2pc rotors...
I have car ADD
Also, isnt 2pc rotors cheaper when needing to replace them? as you re-use the "hats" and only change the disc portion....
Kennedy.. can you compare the dust level to your OEM brembo pads? big difference? these brembos are killing me... every like month or two, i need to pull the front wheels off, and clean the inner barrel and the calipers, because it gets soooooo dirty.
thanks man
thanks man
OMGWTF4THGENTL
thanks man
thanks man
Give me a few weeks
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
