Quick question about headlight bulbs?
Old Feb 4, 2012 | 03:11 PM
dAngjimmy's Avatar
Honda-Tech Regional Coordinator
I just picked up my 2004 Acura TL and have a couple questions.
I searched DRL mod and didn't find what I was looking for.
DRL = Daily running lights?
I just noticed I had another set of lights I could turn on today in my headlights. One of which is burned out. I would like to replace these with a yellow bulb.
Is it possible I can make to where these lights will come on with the corners instead of the headlights?
I don't mean to create a repeated topic, but I couldn't find what I was looking for or perhaps I wasn't using the proper search terms.
Any help is appreciated.
TIA!
Old Feb 4, 2012 | 03:17 PM
RainSupreme's Avatar
DRL - Daytime Running Lights
The 04 models have DRL's and Foglights in the headlight housing, you probably have a foglight bulb burned out
You could most likely do the independent foglight switch mod where they will come on with the parking lights, there is a thread about this just do a search!
Here's the link:
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-07-08-3g-tl-independent-hid-fog-lights-stock-switch-798978/
Old Feb 4, 2012 | 03:26 PM
dAngjimmy's Avatar
Here's the link:
https://acurazine.com/forums/showthread.php?t=798978
Thank you sir. I'm just kinda confused. DRL and foglights?
On the left of the steering wheel i have a switch i can turn and it turns on a set of lights that only come on with the headlights... other than that I wasn't aware of any other lights.
So what is the difference between DRL and foglights in the headlight? I don't have any DRL i don't think or nothing is automatic.
Apologies i'm a total noob to the newer Acura generation.. I guess this is what happens when you stick to EG Civics and DC Integras. :P
Old Feb 4, 2012 | 03:37 PM
jo-nathanpham's Avatar
DRLs didn't come with the TL until 07-08, and Canadian models (I believe).
The burned-out light you are referring to is your fog light.
If you want yellow fogs, Hoen is a popular replacement bulb. https://acurazine.com/forums/3g-tl-2004-2008-93/h%F6en-endurance-fog-light-bulbs-841348/
RainSupreme, I think your link is for 07-08 TLs, while OP has a 04. Jimmy, you might be interested in this thread: https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
Old Feb 4, 2012 | 03:42 PM
If you want yellow fogs, Hoen is a popular replacement bulb. https://acurazine.com/forums/showthread.php?t=841348
RainSupreme, I think your link is for 07-08 TLs, while OP has a 04. Jimmy, you might be interested in this thread: https://acurazine.com/forums/showthread.php?t=772633
Good look! Didn't realize that
Old Feb 4, 2012 | 03:49 PM
dAngjimmy's Avatar
Excellent. This is exactly what I was looking for.
Old Feb 4, 2012 | 04:37 PM
dAngjimmy's Avatar
One other quick question. I have two friends that both own 03 Acura TL's as well which experience this same ''noise''
For the first time since I got the car it was really quite at idle, no heat or radio and I kind of hear some chatter or slight faint clunking noise.. almost like a tensioner, but everything appears to be fine. Runs and drives great just a slight noise I just recently noticed?
Anyone else experience this?
P.S - I searched, but all threads appeared with suspension issues.. this is just a slight noise i'm hearing, but cannot pinpoint.
TIA
Old Feb 5, 2012 | 04:46 PM
That's tough, maybe you could pinpoint to a general location
pplcrew
Jan 30, 2021 08:59 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
acuraST
Sep 17, 2015 02:31 AM
datadr
Sep 12, 2015 09:12 PM
