quick question about brakes
I'm not sure if that's accurate for all TLs. Mine uses a small drum brake for the hand brake. The rear discs and calipers are hydraulic and linked only to the brake pedal. Somehow I think all 3G TLs are like this. Check it out.
Really? I could be mistaken, then...but, this doesn't affect the OP's need to replace his rear brake pads.
the rear brake pads operate against the disc in order to stop the car
INSIDE the center of the rear rotor is a set of mini brake drum style shoes- using the rotors center hub as their brake drum
Notice how wide that rotor hub is? thats why
Should not need adjustment too often and does not change the need for rear pads when those get low
Only an issue when replacing rotors and need to adjust park brake action to the new rotor
