Question on Wheel size....
Will the OEM P235/40/R17 tires fit on a narrower wheel, or would you need to purchase new tires along with the new wheel?
That's the one thing I did not understand with TireRack's tire recommendations after you pick a wheel. Is it safe to assume that if a car can take a 17x8 wheel that it can take the OEM P235/40/R17 tires?
Why would TireRack recommend using 215/50/R17 tires on a 17x8 wheel? (I'm trying to figure out why they sell 17x8 wheels for a 2000 Honda Accord EX v6 but the tire size seems to be excessively narrow (215 vs 235).
IMO if you are going to spend the $$ to get new wheels, why not improve the look with larger wheels. Getting aftermarket wheels that are the same size seems pointless, expecially given the fact that the stocks are not that bad looking. Just seems like a big waste of cash for a barely positive result.
If you go with a narrower wheel, you will probably be compromising handling for appearance. You may not drive the car hard enough to notice, and appearance may be more important to you. My advice is to stick with the stock 17X8 dimensions. This may limit selection, but it's hard to go wrong performance-wise with this approach.
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
