Question re: replacement DVD ROM? (2004 base TL)
Old Sep 10, 2019 | 09:52 PM
Jason Ramoz's Avatar
3rd Gear
Hello does anyone know if I were to replace my DVD player in the trunk would I need the VIN or security code from the car it came from or would it just plug and play? I am getting the dreaded ‘please check disk” navigation error, and I already cleaned the laser with alcohol which didn’t help. My NAV disc is in good shape so I doubt that’s the problem. I looked into the latest disc update for my year TL (04) and looks like the 2014 disc will run me $100 from the AcuraNavi website. I figured if I pulled a cheap dvd rom from a junkyard or eBay I could try that before the new disc. Any info would be appreciated, thanks!
Old Sep 11, 2019 | 01:42 AM
Will Y.'s Avatar
Registered but harmless
You'll need the security code for the Navi if you disconnect the DVD drive.
You'll also need the security codes for the Navi and radio if the battery is disconnected or dies.
Old Sep 11, 2019 | 01:14 PM
3rd Gear
Yes I have the codes needed for my car. Are you saying I’ll need the codes from the donor car as well?
Old Sep 11, 2019 | 06:03 PM
truonghthe's Avatar
you will need a code for the new (replacement) unit.
Old Sep 11, 2019 | 08:08 PM
3rd Gear
Ok thanks a lot I guess I’ll have to pull the vin from wherever I get it from
Tereus0624
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2020 06:35 PM
leedogg
242
Aug 1, 2016 09:34 PM
pererau
Oct 6, 2011 10:29 PM
skyy406
Feb 8, 2006 09:30 AM
garry57
Aug 21, 2005 07:57 PM
