Question on part for window
I'm looking to replace one of two plastic pieces that attaches to the drivers window. This then connects to the window regulator to move it up/down.
in this picture look at the bottom of the window and you'll see two small square objects on the bottom of the glass. Thats what I need.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Since its item # 20. I scrolled down and it says bolt, flange.
required (4).. im understanding it as 4 bolts.
im assuming thats only the bolt and not the plastic pieces?
Yup, that is just for the bolts, not the plastic pieces you speak of.
I assume those plastic pieces come already attached to the window. Stop by parts department at acura, and they can confirm for you
handsom-hustla
11-13-2015 05:04 PM
ahsm
09-09-2015 08:35 AM
