Question for manual transmission drivers
Recently, I was listening to Car Talk on the radio and they briefly mentioned that it's bad to rest your hand on the shifter while driving. I've never heard of this and was wondering if and why this is true. They never went into why it was bad. I admit I rest my hand on the shifter but not hard enough that I make it move at all. Now I'm worried!
Originally Posted by Yakuza70
...but not hard enough that I make it move at all. Now I'm worried!
You can't ride the clutch just a little or rest your hand light enough on the shifter. You either do or you don't . I vote don't.
Dang, this is another bad habit I gotta give up? I always have my hand on the shifter while driving, but I never have the clutch depressed while stopped. I guess I can have that hand on the steering wheel and the other arm against the window. *sigh*
I had a car within the past 10 years in which the owner's manual clearly stated not to rest your had on the shifter while the engine was running.
Now for some facts. As you move the shifter from neutral toward a gear selection, the first thing that occurs in the transmission is the shifter fork for that gear starts to move its collar toward its mating hub (you do NOT shift gears in a manual transmission - you move collars with dog teeth into hubs). As it does this, there will be a point in the shifter movement where the synchronizers will engage in order to begin the process of matching shaft speeds. It doesn't take much pressure on the shifter to cause this to happen. Doing this while the clutch is engaged is NOT a good practice and will most definitely shorten the life of your synchronizers.
So my advice as far as resting your hand on the shifter is this. No harm done when you are moving and the shifter is in gear (just don't move it). When in neutral, sitting at a light or a stop sign or such, best to avoid doing this. If you have experienced the transmission "popping out of gear" problem, I would avoid doing it in that gear.
In urban driving and daily commuting in the DC area, it's hard NOT to keep one hand on the shift a lot of the time whether you want to do so or not. My feeling is that you drive as you need to and you can't get bent out of shape over every little possibility. I mean, shit, I knew a guy who would use his turn indicator to signal that he was moving into the left turn lane, then he'd turn it off whilst sitting in the turn lane, then turn it back on when the light turned green. Why? "So the bulb won't wear out as soon." Dumbarse.
Mike Bertram
Sep 10, 2015 09:27 AM
asahrts
Sep 4, 2015 05:55 PM
