Question from a CL-S er
Time to look for a new car for my wife. Two questions:
1) Are the tranny problems solved with the new model?
2) How about the brake rotors. Are they still easily warped?
there have been no significant tranny problems for the 3rd gen TL. some early 04 models did get recalled for the oil jet fix for second gear. if you are really worried about this problem you can also contemplate getting the 6MT which has been trouble free so far.
there hasn't been issues regarding the brake rotors warping either. there was a couple of posts about brake rotors warping but they are more or less isolated incidents and have yet to be pervassive.
I've been gentle on my brakes, but have a little warpage. Not bad for 68k though.
It seems to have been a weak point in the CLs and earlier TLs.
From the Desert 2 the sea
I also have a CL (w/auto) and now 12k on my '04 TL and have not had any rotor problems.
Did get the oil jet kit for the TL's tranny.
I suspect like you I've had several visits related to the CL's tranny.
Replaced once.
I have recently replaced the motor mounts at around 61k. Thankfully, it was covered under the extended warranty.
Replaced once.
My Brembos are still going strong at 30k miles. The pads are starting to make a little bit of noise, but there is no sign of warpage.
5at
Originally Posted by Starter
Thanks. I've got the 6MT in my CL-S, the other half wants the auto.
On to the tranny issue. In 04 when they recalled the 3G for the oil jet, my 01 was included in the recall. I had an 03 tranny in my car as well. As far as I can tell that the oil jet is now installed on the later 04s and 05s at the factory. It appears that the oil jet was an issue all the way back to when they introduced the 5AT in the fall of 00.
I would not say it has been resolved, but more or less addressed. The 3G puts out torque higher in the RPM band than the 2G which to me was to prevent the AT issues they were seeing. That and some ECU changes that they probably made which I noticed on the 2G. Otherwise, I would have thought that they would leave everything alone and just upped the compression resulting in more power at the same RPM.
Myself personally, I would tend to go with the 6 speed and hold off on the 5AT until you know more. The 3G has been in service for just over a year, so you cannot tell too much just yet. I would say I have not heard of anyone with a tranny failure that was more common in the 2G, but then it took a while for that to happen. Of course you hear about driveline vibrations... , etc...
8k miles on '04 NBP 6MT and very pleased. I previously had an '01 CL-S, never experienced tranny issues however warped rotors twice. IMHO the 3rd. gen is a nice improvement over the previous model. I have had no problems with the '04, with the exception of the flatspotting tires when cold. You won't regret the 3rd gen. As much if not more fun to drive than 2nd gen.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
