a question
Old Jan 3, 2006 | 07:31 PM
Mizouse's Avatar
a question
so i got this magazine from acura, called Acura Style, is it true teh 3G TL has a solar sensing GPS-Linked climate control system?
and i wonder what they mean by GPS-Linked
Old Jan 3, 2006 | 07:40 PM
PoochaKannInc's Avatar
Shift_faster
Basically, there is a solar sensor on the right front portion of your dash. It senses where the sun is (based on which direction you are headed [i.e. GPS-linked]).
It then adjusts the climate control so that if you have selected 70 degrees, but the sun is shining down on your side of the car, in actuality you might be getting 68 degrees to compensate for the warmth. At least, I think that's what it does.
Old Jan 3, 2006 | 07:45 PM
havokgroup's Avatar
Pooch...well said!
Old Jan 3, 2006 | 07:54 PM
Mizouse's Avatar
interesting.. so what exactly does the GPS have to do with anything? cause i know that my 1st gen TL has solar sensors as well and does the same thing.
does it make like the air blowing on the left side of the car a bit colder to compensate if the sun is shining on the left side of the car?
and what about those w/o navi?
Old Jan 3, 2006 | 08:09 PM
HiTEC's Avatar
It's supposed to use the GPS to know where the sun is in the sky. It knows where you are, what direction you're going, where the sun is located in the sky (based on time, I think).
Old Jan 4, 2006 | 04:54 AM
SouthernBoy's Avatar
Registered Member
Yep, you got it. This is how it works.
Old Jan 4, 2006 | 06:45 AM
KilroyR1's Avatar
HMFIC
Sounds like the answer to the question nobody asked.
Old Jan 4, 2006 | 08:19 AM
mamboking's Avatar
So they got this sophisticated temperature changing technology in the 3rd Gen TL and they can't turn the ligths of the car ON when it gets dark.....
Old Jan 4, 2006 | 08:34 AM
scrb09's Avatar
or rain sensing wipers
Old Jan 4, 2006 | 08:43 AM
Shift_faster
Why? Why???
I just never understood the point. But even with the solar-sensing climate control, I don't see a "need".
I'll never get these gimmicks. But I don't mind...as long as I have a way of ignoring it or turning it off.
Old Jan 4, 2006 | 08:56 AM
zax123's Avatar
Team Anthracite Member
mamboking,
I just installed an auto-headlight module. See this thread:
https://acurazine.com/forums/religion-politics-18/ok-classist-128786/
It works perfectly. Never need to touch my headlight switch anymore!
Rob
Old Jan 4, 2006 | 09:31 AM
mamboking's Avatar
Originally Posted by zax123
mamboking,
https://acurazine.com/forums/showthread.php?t=128786
Rob
Kudos to you sir!!!
My for spending my time in the ramblings forum rather than looking for the real important threads.....
Old Jan 4, 2006 | 10:46 AM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Actually, the GPS system tells it where the sun is and you can even see this info through the diagnostics screen. The sensor on the dash just detects whether or not it's actually sunny. The sun may be straight overhead, but you might be in the shade or in heavy, dark rain, in which case you wouldn't want the system to try to chill you more.
It's a bit gimmicky, but it's kinda cool to hear the airflow changing out of the vents as you take turns through city streets.
Old Jan 4, 2006 | 11:02 AM
Registered Member
Yeah, thank God.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
