Question: From '05 TL front converting to Type S front end.
Old Nov 6, 2012 | 10:55 AM
mashie210's Avatar
I tried to search it up but couldn't find anything. So I am hoping someone have the answer for it. Planning to swapping my 05 tl front end to 07-08 type s front end. I am sure there are some mods needs to be done to fit the bumper and headlights. But what are the mods I need to get done to get them fit? And plus how's the fitment ? Do I need additional parts other then headlights, bumper, and the grill ?
Old Nov 6, 2012 | 10:56 AM
mashie210's Avatar
Btw thanks in advance for those who contribute to this thread.
Old Nov 6, 2012 | 11:00 AM
the 04-06 has the same dimensions as the 07-08 bumpers.
after all, it still is a 3G TL.
you will need no modifications, as it will bolt right up.
however, the grille trims do not fit on the type-s bumper.
you will need to buy
-the grille or mesh behind a-bar
-the A-bar with the A
-2 lower grilles
-2 foglights
and bumpers do not come painted. you will have to get it painted
Old Nov 6, 2012 | 07:54 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
You'll also need the TL-S V shape outline trim for the upper center grille. And, you'll need the TL-S hood trim. The 04-06 & 07-08 base hood trim is satin silver, the 07-08 TL-S is black chrome. You'll want all TL-S parts so all the trim pieces are color matched black chrome. It wouldn't look right if the hood trim stayed satin silver, and other parts were in black chrome.
You might want to re-think the TL-S headlights. The existing headlights will work fine with TL-S bumper parts. Going to TL-S headlights would cost quite a bit, I also think the factory HID igniter size is different (bolts to the lower headlight housing).
Old Nov 6, 2012 | 09:56 PM
mashie210's Avatar
Thanks a lot guys ! This helped alot !
Old Nov 9, 2012 | 09:04 PM
A5thProductions's Avatar
5th Gear
Hey guys, Would it do the same for the back end swapped for a tl-s into the 05...wat would be different exept exhaust end movement...
Old Nov 9, 2012 | 10:37 PM
IamaTL's Avatar
I like turtles
https://acurazine.com/forums/3g-tl-2004-2008-93/e-121-diy-installing-type-s-aspec-rear-lip-base-tl-bumper-709992/
Old Nov 16, 2012 | 08:35 AM
Gray world51's Avatar
Anyone know where I can I a find a Tl-typeS front bumper???
I own a 04 Tl
Old Nov 16, 2012 | 09:06 AM
^yes, from the dealer.
its about $250 and then you gotta get it painted.
Old Nov 16, 2012 | 09:09 AM
I have the 04-06 hood trim.
and then the 07-08 v-trim.
Honestly, its not as bad of a color combination one would think.
Old Nov 16, 2012 | 11:02 AM
Mrtastygoody's Avatar
Level: Noob
So how much is the
-mesh
-a bar
-grilles
-fogs
Old Nov 19, 2012 | 02:22 PM
Thanks killer g & justnsapce
Feb 25, 2020 09:57 AM
IIDXholic
Oct 8, 2015 07:53 AM
08 NBP TL
Sep 8, 2015 08:49 PM
ellisd03tls
Sep 8, 2015 04:17 PM
truonghthe
Sep 7, 2015 11:17 PM
