Quad Tips
Old Oct 16, 2009 | 06:47 PM
maddsiick's Avatar
Mistuh DRiiVA
Quad Tips
Are there any quad tips to fit the 04-06 TL with rear aspec lip? Ive been looking for months now and looking on this forum but I cant find anything. All I can find are tips for the type s rear lip. Any help would be appreciated.
Old Oct 16, 2009 | 08:30 PM
CUCU28's Avatar
Nope, ive been looking also, no sucess
Old Oct 16, 2009 | 10:04 PM
pnoi521's Avatar
Registered TL Owner
Maganaflow. They look kinda weird cause they have to be smaller due to the smaller opening. If you go into the regions section, then look at "nor cal post your rides" or something like that theres a pic of a 04-06 with aspec and magnaflow quads, and then a pic of my car with the staggered magnaflow quads
Old Oct 17, 2009 | 07:42 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
Yeah it's do-able. But as mentioned, looks very awkward. The single looks a hell of a lot better with 04-06 base or A-spec.
If you want quads, do the 07-08 A-Spec TL-S lip mod.
Old Oct 17, 2009 | 10:28 AM
rockyfeller's Avatar
King of NYC
It's been done, I have seen a couple pics on the forum. It's doable. The tips look too small and crowded in there though. Look at the way aftermarket quads look in a Type-S lip. Those look like performance.
Old Oct 17, 2009 | 10:48 AM
Etohprn247's Avatar
KoolKatz..
Old Oct 17, 2009 | 11:10 AM
maddsiick's Avatar
Mistuh DRiiVA
i should have thought about this before i bought my aspec kit...but i didnt want to have to go through the hassel of repainting the lip and cutting my rear bumper to fit the type s lip on the bumper, now it looks like im stuck with the dual exhaust instead of quad setup now. Magnaflow doesnt look that bad though, its a possibility....if anyone else has done anything it would be greatly appreciated.
Old Oct 17, 2009 | 11:17 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
atlp base exhaust is still quads...
Old Oct 17, 2009 | 01:29 PM
KN_TL's Avatar
I tried like hell to do quads when I did my exhaust but nothing I mocked up looked right to me. They really need to be much larger than the base opening would allow.
But this is also a personal preference.
Make some tubes or cutouts of various tips available and try it yourself.
Old Oct 17, 2009 | 05:44 PM
Red Voodoo's Avatar
Area on my XM
Originally Posted by Etohprn247
These actually don't look bad... at that angle. Can you please post a few more pictures from different angles so we can get a closer look at them? Are they custom mufflers, or an upgraded catback exhaust?
Old Oct 17, 2009 | 07:04 PM
maddsiick's Avatar
Mistuh DRiiVA
^^^im leaning towards this too, this looks pretty good for base
Old Oct 18, 2009 | 07:42 PM
Etohprn247's Avatar
KoolKatz..
Stock mufflers with aftermarket tips, custom welded on. Anyhoo I'll give ya different angle later still at work.
Old Oct 18, 2009 | 09:13 PM
maddsiick's Avatar
Mistuh DRiiVA
^^^thats an option...any quad tips you can recommend that would fit??
Old Oct 18, 2009 | 11:43 PM
Red Voodoo's Avatar
Area on my XM
Nice. If you can, please see if you can take a decent picture of these tips straight on from the rear of the vehicle. I would also be interested in seeing the weld work as well. What are the diameters of these tips? Thanks for working on this for us that are interested.
Old Oct 19, 2009 | 12:03 AM
pnoi521's Avatar
Registered TL Owner
hey red voodoo you should come out to some of the Sac meets!
then you can see my quads! haha
Old Oct 19, 2009 | 09:18 AM
Bubz's Avatar
SSgt. Hood
ATLP Quads are the Shit..
Old Oct 19, 2009 | 05:39 PM
Etohprn247's Avatar
KoolKatz..
(AssuredAutomotive)
Specs:
Part# ACDDW2.25
Material: T304 Stainless Steel(1.99 mm)
Inlet Size(ID): 2.25"
Outlet Diameter(OD) of each Outlet: 3.0"
Total Outlet Dimension(each Tip): 6.4"w X 3.0"h
Length of Outlets from Inlet: 8.9" & 9.75"
Special Features:
Triple Chrome Dipped finish
Staggered Outlet Lengths for Left and Right side applications
Designed to follow body lines
Double Wall Outlets
Slanted and Beveled Outlets
Total Custom Universal Tips
Can Be use on CARS/ TRUCKS/ SUVS
Weld on style..All high end tips are weld on. NOT clamp style
*Weld this tip on to keep it from growing legs and walking off!!!
Old Oct 19, 2009 | 10:19 PM
Red Voodoo's Avatar
Area on my XM
Thanks for the parts info. Any other pics of these on a TL? They look to be a little big to fit between the bumper outlets of the A-spec rear.
Old Oct 19, 2009 | 10:49 PM
Red Voodoo's Avatar
Area on my XM
Ok. I rescind that last comment about it looking too big. It looks possible (well, if you did it with the same tips, then it is). I just want to see a better view before I order these things. Thanks again for dealing with all my hassle.
Old Oct 22, 2009 | 10:45 AM
mattellis123's Avatar
NCTL05 has these tips on his TL. Check the link and see if you still like.
https://acurazine.com/forums/showthr...ghlight=NCTL05
If you could get this set with 2.75"dual tips , instead if the 3" tips I would buy them. I found a set on jegs.com that has 2.5 dual but I think they might be to small. Just some info from my research
Old Oct 22, 2009 | 10:58 AM
maddsiick's Avatar
Mistuh DRiiVA
those still look really big compared to size of the gap in the bumper for the exhaust. it seems to crowded but i guess it really is that hard to find nice quad tips for the 04-06 TLs
Old Oct 22, 2009 | 12:50 PM
myron's Avatar
if you deside to get the type-s rear lip to fit the quad tips, I will get the base a-spec off you haha
Old Oct 22, 2009 | 02:27 PM
These are 6" wide compared to the set that NCTL05 aad the set post by Ethron247 which are 6'4" wide. From his pics it loofs like .5' is about what is need so they will slide into the origonal spot of the exhaust.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Timmy18
Oct 17, 2015 03:58 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
ivan06106
Sep 26, 2015 04:38 PM
