Quad Tips
Mistuh DRiiVA
Quad Tips
Are there any quad tips to fit the 04-06 TL with rear aspec lip? Ive been looking for months now and looking on this forum but I cant find anything. All I can find are tips for the type s rear lip. Any help would be appreciated.
Registered TL Owner
Maganaflow. They look kinda weird cause they have to be smaller due to the smaller opening. If you go into the regions section, then look at "nor cal post your rides" or something like that theres a pic of a 04-06 with aspec and magnaflow quads, and then a pic of my car with the staggered magnaflow quads
Yeah it's do-able. But as mentioned, looks very awkward. The single looks a hell of a lot better with 04-06 base or A-spec.
If you want quads, do the 07-08 A-Spec TL-S lip mod.
Mistuh DRiiVA
i should have thought about this before i bought my aspec kit...but i didnt want to have to go through the hassel of repainting the lip and cutting my rear bumper to fit the type s lip on the bumper, now it looks like im stuck with the dual exhaust instead of quad setup now. Magnaflow doesnt look that bad though, its a possibility....if anyone else has done anything it would be greatly appreciated.
I tried like hell to do quads when I did my exhaust but nothing I mocked up looked right to me. They really need to be much larger than the base opening would allow.
But this is also a personal preference.
Make some tubes or cutouts of various tips available and try it yourself.
Area on my XM
Area on my XM
Nice. If you can, please see if you can take a decent picture of these tips straight on from the rear of the vehicle. I would also be interested in seeing the weld work as well. What are the diameters of these tips? Thanks for working on this for us that are interested.
KoolKatz..
(AssuredAutomotive)
![](http://www.assuredautomotiveproducts.com/images/1209504446013-864804351.jpeg)
![](http://www.assuredautomotiveproducts.com/images/1249258138665627628683.jpeg)
![](http://www.assuredautomotiveproducts.com/images/BumperR_30.JPG)
Specs:
Part# ACDDW2.25
Material: T304 Stainless Steel(1.99 mm)
Inlet Size(ID): 2.25"
Outlet Diameter(OD) of each Outlet: 3.0"
Total Outlet Dimension(each Tip): 6.4"w X 3.0"h
Length of Outlets from Inlet: 8.9" & 9.75"
Special Features:
Triple Chrome Dipped finish
Staggered Outlet Lengths for Left and Right side applications
Designed to follow body lines
Double Wall Outlets
Slanted and Beveled Outlets
Total Custom Universal Tips
Can Be use on CARS/ TRUCKS/ SUVS
Weld on style..All high end tips are weld on. NOT clamp style
*Weld this tip on to keep it from growing legs and walking off!!!
Specs:
Part# ACDDW2.25
Special Features:
Double Wall Outlets
Area on my XM
NCTL05 has these tips on his TL. Check the link and see if you still like.
https://acurazine.com/forums/showthr...ghlight=NCTL05
If you could get this set with 2.75"dual tips , instead if the 3" tips I would buy them. I found a set on jegs.com that has 2.5 dual but I think they might be to small. Just some info from my research
![](http://www.jegs.com/images/photos/900/958/958-EVT19.jpg)
Mistuh DRiiVA
those still look really big compared to size of the gap in the bumper for the exhaust. it seems to crowded but i guess it really is that hard to find nice quad tips for the 04-06 TLs
These are 6" wide compared to the set that NCTL05 aad the set post by Ethron247 which are 6'4" wide. From his pics it loofs like .5' is about what is need so they will slide into the origonal spot of the exhaust.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
