Potential transmission problem?
Woke up this morning to drive my 07 TL and I got a flashing error on the dashboard/navi saying there was a transmission problem with the car. I open the hood and my coolant is all gone, there is a purple-red-ish oil all over the ground. Not sure what happened.. any advice? Car has 95k miles on it so I know I'm not too far away from the 105k service. I keep up to date with all fluids and maintenance on the car.
Thanks,
AJ
Thanks,
AJ
Thanks,
AJ
Thanks,
AJ
Originally Posted by YungMoola15
most likely bad radiator or water pump. Your tranny is most likely all good. I believe the radiator has hoses inside the tranny so that explains the red tranny fluid leaking. I would do the 105k service and change the radiator
There are transmission cooler lines going to and from the radiator and transmission . It's the radiator. Go buy a new Denso one on Amazon and new upper and lower radiator hoses too. Two gallons of Honda blue coolant and a few quarts of transmission fluid to fill her back up and you'll be rocking in no time!
Ahmed Nomaw
Jul 20, 2017 04:06 PM
