Piston Soak with Berryman B12 (116)
Old May 24, 2025 | 08:31 PM
VictorTL's Avatar
I am trying to do a piston soak in the cylinders using Berryman B12 (116) and my all of my pistons can’t seem to hold the solvent longer than 5 minutes . All the B12 solvent immediately drained into the crankcase after I poured through the spark plug holes.
Does this mean my piston rings aren’t clogged or stuck closed?
i saw YouTube and the liquid should be stay inside the cylinder at least 6 hours or more for the solvent to dissolve the carbon on top of the piston.
Any inputs?
Old May 24, 2025 | 08:57 PM
Can you provide a YT link to the video you watched?
Old May 24, 2025 | 09:37 PM
VictorTL's Avatar
Old May 25, 2025 | 04:21 AM
Any inputs?
It appears there are no short-cuts for the V6 piston soak.
Looks like you have to do 3 pairs of two cylinders, 24 hours at a time at TDC, for a 6 cylinder engine?
He sums it up starting at @37:50.
Old May 25, 2025 | 08:27 AM
VictorTL's Avatar
I know but all my 6 pistons don’t hold the solvent longer than 5 minutes. All the solvent drain to the crankcase almost immediately after I poured through the spark plug holes.
Old May 25, 2025 | 06:08 PM
Try placing cylinder #1 & 4 at TCD, pour in appropriate amount of solvent slowly, then recheck.
Similar to what the guy on the video advocated for the V6 engine.
Do you have a bore scope camera to make the 'checking' easy?
Old Jun 6, 2025 | 10:26 AM
Hey OP, did you ever get this TDC Berryman B12 piston soak process to work like the guy in the video?
bg2128506
Feb 6, 2019 09:15 PM
VictorTL
Oct 23, 2018 06:18 PM
us000011
Apr 18, 2005 11:29 AM
Arcticcl9
Jan 19, 2005 12:15 PM
